Old 02-05-2006, 07:04 AM   #16
jag
jag's Avatar
Originally Posted by maskedrider
hmm.... me only used tubing on the stinger and the rest used only plastic bag tie with a rubberband....hope i using the right way
Like Dan said, cover all of the openings in the pipe. I wrap a golf tee in plastic and jam it into the stinger, use a piece of fuel tubing with a bolt in it for the pressure line and I use a small clamp to cover the end. I also wrap a few zip-ties around it so it doesn't expand. I check on it every 30 minutes. I would not try prying it unless you get it hot first.
Be patient... it will work.
jag is offline   Reply With Quote
Old 02-05-2006, 07:27 AM   #17
maskedrider's Avatar
thanks for the advised given....
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Dented Pipe?? NitroMaxx3.3 Nitro On-Road 23 07-18-2007 05:28 PM
Dented Carb..Help jetbill007 Onroad Nitro Engine Zone 3 01-18-2007 01:03 PM
how to fix a dented pipe uniquexme Nitro On-Road 12 08-30-2006 08:31 PM
Reforming dented dual-chamber pipes? chachi Nitro On-Road 10 05-15-2003 12:32 AM
