New Style Clutch for 1/8 GT
#31
hi dan were you able to get and test this new clutch system on your car the serpent i just got one and
want to try out but got no manual on how to put it together and i dont want to damage it if you know please let
me know with pics or something thanks in advance i have a serpent 3.1
#33
Please don't take this as an attack on yourself, but a lot of guys think this way, and I am afraid of the consenquences that thinking might have. Some think "if this is a proper onroad class why shouldn't we use Lola wedge bodies", others say "this is a proper onroad class now why can't I have a belt car", I even hear guys wanting to switch to foam tires. If you add all of that up, don't you see where it ends up? What would be the point of it anyway, if you want an ugly wedge foam belt car with Centax just go run 1/8 or 1/10.
Keep GT just as it is: shaft driven, kickup (I don't care if it's stupid, keep it), buggy clutch, GT body and rubber tires. It's an awesome class, let's keep it this way and let it grow.
#34
I can live with the clutch but kick up has to go. I have owned 3 GT cars from 3 different manufactures. All had caster issues. Serpent was the first to fix it with caster blocks and correct a and b blocks. Mugen, I had to modify the the front of the car. HB is my current car and I had to flip the b block and dremel it with 6 degree caster blocks to get the caster out. All the caster was destroying my front tires. With the caster reduced, my front tires wear evenly and I have lots of steering.
For the average guy trying to get into onroad, GT is a good way but it should come ready out of the box without having to buy other parts and modify things. I think the serpent car is that way now. Also, the new IGT8 is ready ready to go too. I don't mind tinkering and developing cars. I enjoy the challenge. But for the new guy, I think it isn't the best idea.
#35
Actually in Europe (EFRA) and UK (BRCA) rules there is a specific restriction to 'Only buggy based 2,3,4 shoe clutch. Radial type clutches are not allowed' and so to keep within the spirit of the rules I'd say that this particular style of clutch would be illegal at the European GP or IR. There isn't any buggy out there that comes with the style of clutch in my OP so it is not within the spirit of the current rules.
However people are using it and getting away with it and it does seem to be a significant step forwards and so I need to get one in order to keep up. It's the nature of the beast I guess pushing the limits of the rules will always happen and until it is expressly used as an an example of what is not permitted people will continue to use it. Besides the clutch is never checked during tech inspection anyway
#36
Maybe lets get the terminology right first although most of us understand what's meant I guess. The buggy clutch so to speak is in my physical world the radial type and the centax is the axial type. For a very simple reason: The buggy shoes move in a radial way while the centax shoe is moving in an axial way. My personal opinion: Clutch should be free. The problem most people have is that they can only think in boxes,..in what they know,..in what they are used to...in other words they are afraid of change. You only have to look at the function of what the clutch actually has to do in order to understand that the discussion is pretty useless. ...oh yeah ..then there is the cost argument..thats a joke in my opinion if you compare that to all other costs RC racing is bringing you........
reg
willem
reg
willem
#37
I hear all of u with solid views and opinions, but why nobody speaks of the characteristics and demands on road racing poses.
u have heavy cars, with high grip racing that demand specific tuned motors to perform.
similarly an appropriate clutch should be developed to match this criteria.
So if this inbetween clutch fits the bill, then perhaps there should be a compromise.
i agree that GT class should be based on an existing buggy platform..
but ask yourselves why did we ditch the center diff to a dual speed setup.
why did we lower the towers to change geometry.
why do motors need different timing
and so i really wish and hope with time the class gets a cluth that would be a mix of both worlds, but with the specs to cover the needs of running ON road...
#38
For a part that the guys making the rules can not think or are informed about everything to keep any gaps in the rules closed.
For the last part, you do not want to have a rulebook of a thousend pages with as result a 1 hour technical inspection on a car and engine.
#39
Is GT8 going Centax Clutch?
#40
#41
This is no centax clutch. This is just a normal clutch with just a different spring system.
But it will be interesting to see if this step by Xray will change the rules where these clutches are not alowed/
#43
It's amazing how "old" can become "NEW!" again. Picture above was taken in 2004, 15 years ago lol!
#45
Am i right in thinking that these newer clutches like the Werks and Xray you can adjust performance by adjusting compression on the spring like a centex?
