Tuning with chassis weight
Am I right to assume low traction use chassis weight, high traction remove it??
It's way more complicated than that. If you want to read more about suspension tuning check my threads on the statistics tab, http://www.rctech.net/forum/members/30tooth-108876.html
Increasing overall weight of the car is not the solution in low traction conditions.
Within reason, you always want a lightweight car. The idea behind adding weight is to place the bias (front to rear or side to side) where you want---still with a car as close to minimum overall weight as possible. Bias can be changed with ride height as well.
It's way more complicated than that. If you want to read more about suspension tuning check my threads R/C Tech Forums - Search Results
