looking for truggy body dimensions
Hi
I am trying to find bodies that fit my AE RC8T CE and I am looking for some dimensions of other truggys to compare.
The dimensions I am looking for are
The distance from the rear shock tower to the front body posts.
The width of the widest part of the chassis and if it narrows or stays the same.
With the body on a flat surface, the height of the front and rear body posts to the ground. I used a set of calipers for this dimension but a ruler would also work.
And finally the distance from the rear shock tower to the center of the engine.
The last dimension is optional but if you have the nitro version I would like the dimension.
And units can be in either US or metric, which ever is easiest.
The dimensions of my RC8T are
length between shock towers is 368mm
width is 200mm
rear body post height is 80mm
front body post height is 111mm
and distance from rear shock tower to engine center is 130mm.
Thanks for your help
Tanner
width is 200mm
Tanner
