pipe & tires?
pipe & tires?
Just wanted to know if anyone can recommend some tires already glued and some pipes for my rc8b3. I prob might get them from amain hobbies so if there are good ones there please recommend. thanks in advance
haven't got an engine yet. was still building my car. I was going to save the engine for last. im just finishing up the servos. I wanted to spend no more 30 per set
I would make pipe selection after you have decided on an engine. Often times they should be paired together for best performance.
$30 for 4 tires will be challenging as that is the current pre mount rate for 2.
You may want to check out ebay or the classifieds here for tires. Also, see what the people at your local track are running. If you are just bashing or breaking in an engine, I would definitely recommend used tires. Asphalt will eat a set up knobbies in 5 minutes.
im sorry. I meant for 2 tires. I thought I seen some that came with 2 tires. I would spend 65-75 all together. thanks I will wait on the pipe until im ready for the engine.
