Lrp zr .30 one way bearing issue
Hi I just recently bought a lrp zr .30 spec 4 engine and I have an issue with the one way bearing. The issue is were the pin from the crank fits into the one way bearing has worn out the grove were it sits in and makes a rattling noise when running I only have 2 gallons of fuel throu this engin. I've owned other nitro engine but this is my first lrp engin and just wandering if this is normal ware every thing else looks fine inside the engine. Thanks
Sounds like either inadequate lubrication, excessive starter usage, or perhaps poor quality manufacturing. There should be 4 positions the crankpin can be located to engage the one-way clutch bearing.
Yea im not sure I was thinking not enough lubircation to but when I run the truck it blows good smoke. For starting I use pull start I wander maybe it's the way it's designed and would like to hear if others have had this issue. I called lrp today and left a message so I should get a call tomorrow. I'm using the other side of the bearing now so I can still run the truck I'm sure it's gonna ware the other side out to. I'm trying to upload a pic of the bearing but can't get the pic to upload.
The smoke has little to do with how rich the engine is. Some fuels smoke more. You can tell your tune was too lean if there was no oil residue in the crankcase. As in bone dry. If there was at least a little liquid oil in there, then the cause is like either excessive starter usage or defective part most likely.
When I had the back plate off the other day I noticed there was a nice amount of oil on every thing in there. The engine usually fires up pretty quick even with pull start could this issue happen if excessive starting was the case. No word from lrp today Im gonna call them tomorrow hopefully I can get a hold of them.
