-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   D8t rear center drive shaft (https://www.rctech.net/forum/nitro-off-road/992560-d8t-rear-center-drive-shaft.html)
donnyc2015 07-16-2017 05:09 PM
I have an older d8t with a 3 piece drive shaft in center rear can I replace that with one from a tessman edition?
TRiN 07-16-2017 05:37 PM
Yes, the 166mm shaft with #67406 coupler
Alternatively, with a little more parts the D817T (185mm HD shaft, V2 10T input gear, large bearing diff case and bearings) is also a direct bolt-on... :nod:
Do the same for the front center if you want to go cvd-less in the center (radio tray will need to shaved ever so slightly for clearance as the shaft will be less angled)...
:tire:
