Benefits of a digital powerswitch?
#16
Agreed on how it's supposed to work. With return springs on some carb/car combos they don't work. Rubber band method is decent but again inadequate. So yes perfect world. Perfect circumstances it's supposed to do what you described. No doubt or denying any of that. But as stated. Some servos don't move at all when there is no power. And definitely needs more force than a couple rubber bands and/or a spring.
The servos I currently run do not have this issue. Nor does my car anymore, but it can happen at anytime with any servo when they burn up and lock or break and lock. Even then no amount of hope or force with help you.
#18
It's not stiff when powered up, but with no power .........it's like the magnets in the servo motor are very strong , n that makes the servo stiff 👍🏽. But yes no return spring will save you if your servo is froze open, also be careful wit the Lil cheap switch from eBay. I've went thru a few of them....... Some do last tho. Sounds like it's lemons even in the ko and other more expensive ones also. I'm trying a ko in my new ride, but if I have any problems , going back to direct connect where I've had zero issues
#20
https://www.amainhobbies.com/deans-m...-wsd1222/p3592
#21
I've just been using an extension and plugging it in every race.
What kind of issues have you guys had with this setup?
#22
Tessman recently had an issue I believe with it being worn. At least that's what I heard so don't quote me on it. I've ran the method for years. But with the reliability I've experienced with a digital switch, I wouldn't switch back. At a glance I know my voltage and it's never let me down. I keep an extra on hand at all times. But I've never needed it. Although every year I take a look inside to make sure it's clean. If it's overly dirty I replace it.
#23
Here you go. Same one as the Protek but way cheaper.
SkyRC POWER SWITCH ON/OFF MCU controlled LIPO NIMH Battery Car Heli SK-600054-02 | eBay
#24
#25
you get what you pay for. ive been using 2 KoPropo switches for the last 3 years and they both still work perfectly and have never given me any grief
#26
I also have a Kyosho switch that looks exactly the same that does work perfectly.
Any idea why my Ko Pro does what it does?
#27
because you have the lipo plug in the switch. remove that plug and you can go sub 6v
#29
#30
correct, that activates lipo mode.
