Like Tree35Likes
X-ray XT8
Old 07-03-2017, 08:45 PM
  #61
Originally Posted by Frank L View Post
Here you go. It's a good starting point.
https://goo.gl/photos/fB98nQHNNidLGpjT6
Lmk if that doesn't work.
Photobucket is crazy. That's in google.
Worked for me 👍
Raddog23 is offline
Old 07-10-2017, 03:12 PM
  #62
Which body will come with the XT8? Tessman ROAR Champ body or the Proline Truck body?
brmena101 is offline
Old 07-10-2017, 04:23 PM
  #63
mourinho's Avatar
Trader Rating: 46 (100%+)
has tessman uploaded his roar nats setup anywhere?
mourinho is offline
Old 07-10-2017, 04:49 PM
  #64
Trader Rating: 20 (100%+)
The body that Ty ran at the Nats is made by Proline. It will come with the kits sold in the US and be distributed by RC America as an XRay part.
MX304 is offline
Old 07-11-2017, 08:31 PM
  #65
Frank L's Avatar
Trader Rating: 148 (100%+)
This is the setup that Gord sent to me. Tessman has been using it as a starting setup with few changes track to track
mourinho likes this.
Frank L is offline
Old 07-19-2017, 03:20 PM
  #66
Trader Rating: 33 (100%+)
got mine converted to an Etruggy.. went together very easy.
dgrobe2112 is offline
Old 07-19-2017, 05:01 PM
  #67
how do you like it
coombes is offline
Old 07-20-2017, 06:26 AM
  #68
havent run it yet.. just got it built.. the build went very well..
i used the XB9 servo mount tray, instead of the 3 posts, mainly for flex. i do the same in my ebuggy.
i used the stock upper center diff plate, although, i think using the ebuggy version is better, with shims of course. i didnt have this piece. the stock top piece works, but seems a little close to the spur gear. time will tell.
the stock truck, nitro version, comes with the holes to mount the battery tray. not usual.. cuz typically the nitro version doesnt do this, a Electric chassis is required, but not in this case.
one thing also, this goes for all the XT8 builds.. while it goes together very well.. the lower pills in the lower blocks, are very tight.. make sure when installing them, you install them all the way in. if not, your arms will not be free.
but other than that.. was very nice build.
Old 07-24-2017, 08:28 AM
  #69
truck felt good this weekend.. definitly needed some setup changes to get more steering from the truck. also.. had to get some rear grip out of the truck..
i got a little more testing to do, and some more changes to make setup wise.. but.. sofar the truck is very stable, and easy to drive.
my issues since i havent run truggy for many many years.. possibly 6 years.. was getting used to the truck width. dont know how many times i clipped the pipe with the inside wheels, which flipped, or sucked the truck into the marshal areas.. lol..
our class lap times were so close.. we werent allowed any mistakes.. less than .6 of a second in lap time.. between the top 6.
Old 07-24-2017, 04:56 PM
  #70
mourinho's Avatar
where did you need steering? off power? on power? sweepers?
mourinho is offline
Old 07-24-2017, 06:42 PM
  #71
Pretty much overall. Mainly corner entry. I'm gonna go down in front diff.. The caster bushings are on back order. I did get the rear to loosen up. Which helped with on power push from alot of rear grip..
Old 07-24-2017, 06:54 PM
  #72
mourinho's Avatar
are you getting full steering throw both ways? i noticed when building mine that the servo saver arm makes contact with the radio box lid on full left, requires steering horn to be set with a slight offset from perpendicular to achieve full throw.
dgrobe2112 likes this.
mourinho is offline
Old 07-24-2017, 06:59 PM
  #73
I will double check. Does it hit turning left? Cuz that's where I really noticed it.. left hand hair pins
Old 07-24-2017, 07:03 PM
  #74
mourinho's Avatar
yes left
mourinho is offline
Old 07-25-2017, 06:47 AM
  #75
ok, i will check that out.. but overall very pleased with the truck.. it was very responsive to changes, and each change i made, worked for what i wanted. and even though the truck wasnt where i wanted.. lap times were very competative.
