wheels spin backwards after braking >
Like Tree1Likes
  • 1 Post By Roelof
Old 05-09-2017, 05:46 PM
Trader Rating: 26 (100%+)
Default wheels spin backwards after braking
So I have weird situation. Not sure if it's a problem or not. After a hard brake the wheels will spin backwards. When I give throttle it goes forward again but after I brake starts to go backwards. Flywheel spinning correctly. Diff's are in correctly. It's Werks b5 in a NB48.3. I don't think there anything wrong with the motor....If i have it on a flat surface it will go backwards 5 feet. ON the box it's really noticeable.
tfrankito is offline
Old 05-09-2017, 06:19 PM
It does it on the ground? Thats bizzare. Your not on a hill i assume because thats the only thing i could think of haha.
Maybe check everything is spinning freely, perhaps something is getting bound up and when you break it gets released causing the car to go backwards.
Gavel is offline
Old 05-09-2017, 07:19 PM
Yeah. On the ground. It's not strong enough to go up a hill but I haven't seen anything like this. I was thinking maybe brakes are worn and not staying against the steel plates.
Old 05-10-2017, 12:28 AM
Roelof's Avatar
Probably the wheel on oneside is lifted up and so will turn backwards when the diff has stopped rotating and the other wheel is on the ground rotating forward.
RockStar_199 likes this.
Roelof is offline
Old 05-10-2017, 05:09 AM
Post a video.
pat dillon is offline
Old 05-10-2017, 02:50 PM
I too would like to see a video.
token is offline
Old 05-10-2017, 11:24 PM
So after some discussion with pdillon and trial and error....motor was running in the opposite direction. The one time I buy something brand new and I had to rewire bump box to turn motor the correct way....
https://youtu.be/hICeIUYg7R0
https://youtu.be/xp7KNDvMfQY
Old 05-11-2017, 03:48 AM
kaptain crash's Avatar
Trader Rating: 46 (100%+)
Had that happen long ago during a big race "motorama" my on/off switch fried between heats and my pit man bypassed it. I was stunned that a nitro engine could run backwards.
kaptain crash is offline
Old 05-11-2017, 07:52 PM
wow, never saw that before. Glad you got it sorted out!
Evoking1230 is offline
Old 05-12-2017, 08:17 PM
imaxx21's Avatar
I've see engines set to rich do that on the starter box as well
imaxx21 is offline
Old 05-13-2017, 01:49 AM
Roelof's Avatar
So with a hard brake the engine turns backwards. I think you have to check the clutch. The engine goes to low on rpm due a low idle or a sticky clutch so it can get a backfire and turn backwards.
Roelof is offline
Old 05-15-2017, 03:41 AM
tom1974's Avatar
Start box........
Starting the engine in reverse
tom1974 is offline
