Compatibility and knowldge
Is there a set of front lower arms compatible from a hyper or any other car for he nitro X3 sabre buggy. Also, recommendation s as to a carb that'll wake it up?, And a pipe for any drastic changes. Also if I go one one up on clutchbell,will they mess with acceleration only.or can I change ,1 tooth, to n it's first gear state before differential is going? Will that give me a lil more of line. Any other suggestions for carb,air intake, or different plugs. Can someone professional Ally tell me fair priced items to get c at a little quicker off line but same overall speed and power,unless filters,or plugs, and pipe could change that.tjanks. I wanna order like super soon.thank u
Hi, Your post makes no sense. 1. Do you have a Hong/Nor/ OFNA X3 Sabre buggy? If so which one do you have and what engine is in it. If it the rtr version with the pull start 28 your going to spend a fortune getting it up to par. Hyper parts will not fit with out some kind of modifying the car to make it fit. So to answer your question you have two choices go to ebay and put the car in the browser and look for the parts you need or go to nitrohouse on the web a look up the parts that you need. if you have the 28 engine the pipe you have should work well. Michael
| All times are GMT -7. It is currently 07:59 AM. |
