how many head shims > how many head shims
how many head shims
Old 01-30-2017, 09:51 AM
Default how many head shims
hi ..hope this right place for this
i have an ansmann .28 with os8 plug and 20%, jp2 pipe, if i remember correctly when i first got the engine it had 3 shims on, may have been used at a higher nitro % so how many shims would i use after installing a new piston and sleeve n running it in ..ive been doin the running in with 3 seems ok just seems to have loosened up alot..thanx in advance
karnage1277 is offline
Old 01-30-2017, 02:44 PM
Andy900's Avatar
I'm not an expert but in my experience it's usually best to stick to however many the engine came with. There's usually a reason for the number of shims put in from the factory.
Andy900 is offline
Old 01-31-2017, 05:07 AM
yeah i thought that, but as the ansmann28 has the same internals as the force 28 which comes with 2 standard i thought the arne would be the same ..ill leave it in
Old 01-31-2017, 06:14 AM
ozziii's Avatar
[QUOTE=karnage1277;14820130]hi ..hope this right place for this
No, posts about engines & engine parts/accessories should be in the engine sub forum section at the top of the nitro offroad section.
Stick with what the factory made the engine with & you should be right.
ozziii is offline
Old 01-31-2017, 06:49 AM
yeah thanx ozzii.i see it now..ill direct all further engine questions there in future, have stayed with 3 shims..seems ok
