Tekno NB48.4 Thread >
Tekno NB48.4 Thread
Like Tree70Likes
Tekno NB48.4 Thread
    Hide Wikipost
Old 07-07-2017, 08:14 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno NB48.4 Thread
Last edit by: MattDub
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Aluminum Servo Horn:
-TKR5251B (23T)
-TKR5252B (24T)
-TKR5253B (25T)
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (Rear)
This car is very durable. Here are the spare parts that we recommend you keep on hand:
Tips and Tricks
Vehicle Setup Adjustments and Build Tips
Tekno RC Instructional YouTube Video Playlist
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on our website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Setup Sheets:
Setup sheets for all of our vehicles can be found here.
What is overdrive and when should I use it?
The NB48.4 comes stock with a 12t pinion (TKR8152) and the 39t ring (TKR8151) in both the front and rear and the EB48.4 has a 12t pinion (TKR8152B) and the 40t ring (TKR8151B) in both the front and rear.
The two sets of gears are used to overdrive the front of the EBs or underdrive the rear of the NBs. If you have both vehicles and want to try underdrive it's as easy as swapping the front diff and pinion of the EB and the rear diff and pinion of the NB. Underdrive helps on very loose tracks, when you need more on power steering or if the rear of the car feels loose.
Print Wikipost
Old 03-14-2017, 04:18 PM
  #61
jason07's Avatar
Originally Posted by RokleM View Post
Because it just works
LOL makes sense
jason07 is offline
Old 03-15-2017, 10:55 AM
  #62
allaboutwho02's Avatar
Trader Rating: 45 (98%+)
Any tips on building this car? I have a new one coming. Diff fluids? Shock oils? Anyhting that can help. Thanks
allaboutwho02 is offline
Old 03-16-2017, 08:08 AM
  #63
Trader Rating: 64 (100%+)
TeknoRC has done an awesome job on posting build & setup tips on their site. teknorc.com scroll to bottom under support and see Vehicle Setup Adjustments and Build Tips link. I provided link below as well.
Vehicle Setup Adjustments and Build Tips ? Tekno RC, LLC.
Some videos also found on youtube, search TeknoRC.
If this is your first Tekno build follow the manual which provides best instructions in the industry with helpful tips.
They also have posted setup sheets under each vehicle. View them and choose your setup according to your track condition. NB48.4 JB Smooth track base and JB Rough track base are both good starting points for the conditions. Test how they feel and make changes for your driving style. Changes are easily noticed and you will feel them. Good luck everyone with your builds!
paposwing14 is offline
Old 03-19-2017, 04:47 PM
  #64
mv91pony's Avatar
Build was flawless. As posted get the tekno or m2c servo arms.
mv91pony is offline
Old 03-19-2017, 07:06 PM
  #65
Mikeand22's Avatar
Trader Rating: 30 (100%+)
When you're rebuilding your diff, what kind of grease are you using around the o-ring and out drive if you run out of the kit stuff? Thanks
Mikeand22 is offline
Old 03-20-2017, 09:18 AM
  #66
hairymuffin's Avatar
Trader Rating: 102 (100%+)
Gonna here a lot of suggestions here, Ty's 110% stuff I have used but I really like the tlr green grease, I also use it on my shock orings
hairymuffin is offline
Old 03-21-2017, 05:33 PM
  #67
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
I use red mobil 1 synthetic, doesn't break down like most grease does, holds form,yet does not slow action down at all, best stuff on the planet, for cars etc...lol, serious go grab a can from pep boys when you rebuild them, youll see the red grease STILL IN THERE SEALING AND PROTECTING, and ive tried them all..
brokenmoto likes this.
TommyBlazin is offline
Old 03-21-2017, 05:34 PM
  #68
don't need ty's this, green LOSI that, MOBIL 1 GOOD ENOUGH FOR 5 MILLION DOLLAR FORMULA 1 CARS good enough for your diffs...
Old 03-21-2017, 07:05 PM
  #69
Anyone run the b2102 O.S. in this guy yet? Or Highest dt2100 servos. I'm planning a build.
FNG_CJ is offline
Old 03-21-2017, 07:42 PM
  #70
Hey dude dont disrespect what i said. Its just a suggestion,who ever said one is better than the other? Let the guy decide for his self. No need for you to get mr expert on some frggin grease. Just make your suggestion and move on. Fyi the 110% red stuff is mobil1 ive heard...
Cappy likes this.
Old 03-22-2017, 12:36 PM
  #71
I run Highest DT2100 steering and throttle with no issues.
Old 03-22-2017, 06:25 PM
  #72
Cool. I plan on a m12S system and apparently if you contact them pre sale they can put SSR mode on them.
FNG_CJ is offline
Old 03-28-2017, 10:18 AM
  #73
Anyone know of a 12.9 grade screw kit for this buggy?
FNG_CJ is offline
Old 03-29-2017, 10:01 AM
  #74
Trader Rating: 33 (100%+)
Stock screws are of very high quality (not sure if 12.9, but wouldn't be surprised if they are). Alternatively, I've found bolt depot has the best pricing on various bulk screws, and you don't have to order them in quantities of 100 or 1000 like other places.
https://www.boltdepot.com/Metric_soc...ts.aspx?nv=rel
Based on this, I can't say I've ever seen a "screw kit" for it (other than junk titanium) as it really just isn't typically needed at all.
RokleM is offline
Old 04-01-2017, 11:13 AM
  #75
lala4fire's Avatar
Default notchy diffs!!
has anybody else had to double up on diff gaskets to get the diffs to move freely.
center one is almost locked up and front and rear are super notchy!! This is a new build. Thanks
lala4fire is offline
