Tekno NB48.4 Thread >
Tekno NB48.4 Thread
Like Tree68Likes
Tekno NB48.4 Thread
    Hide Wikipost
Old 07-07-2017, 08:14 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno NB48.4 Thread
Last edit by: MattDub
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Aluminum Servo Horn:
-TKR5251B (23T)
-TKR5252B (24T)
-TKR5253B (25T)
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (Rear)
This car is very durable. Here are the spare parts that we recommend you keep on hand:
Tips and Tricks
Vehicle Setup Adjustments and Build Tips
Tekno RC Instructional YouTube Video Playlist
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on our website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Setup Sheets:
Setup sheets for all of our vehicles can be found here.
What is overdrive and when should I use it?
The NB48.4 comes stock with a 12t pinion (TKR8152) and the 39t ring (TKR8151) in both the front and rear and the EB48.4 has a 12t pinion (TKR8152B) and the 40t ring (TKR8151B) in both the front and rear.
The two sets of gears are used to overdrive the front of the EBs or underdrive the rear of the NBs. If you have both vehicles and want to try underdrive it's as easy as swapping the front diff and pinion of the EB and the rear diff and pinion of the NB. Underdrive helps on very loose tracks, when you need more on power steering or if the rear of the car feels loose.
Print Wikipost
Old 11-30-2018, 09:46 PM
  #271
Trader Rating: 19 (100%+)
Originally Posted by jersey View Post
dont they have to run that kinda wing with the longer sides. I think IFMAR makes you. I think in 5150 video in Vegas? They were altering there wings to comply with IFMAR
All of the manufacturers make their own IFMAR legal wings now, including Tekno. Not sure why so many chose to run the HB wing. Must have been some advantage to it.
MX304 is offline
Old 11-30-2018, 10:28 PM
  #272
yea I know they do now, but I think In the 5150
video for the last worlds I think a lot of them didn’t have them and ty took pieces of lexan onto bottom
of proline wing so he can use it. I know Tlr has a new wing for the x buggy.
jersey is offline
Old 11-30-2018, 11:37 PM
  #273
JQ
No they don't.
JQ is offline
Old 12-01-2018, 08:06 AM
  #274
1/8 IC Fan's Avatar
Trader Rating: 76 (99%+)
I think what JQ is alluding to, is that many still do not, because their Team Drivers have a Body (& Wing) Sponsor as well of which they usually provide a compliant wing, and as such are not bound like the Kyosho Drivers were to run OEM Equipment.,
1/8 IC Fan is offline
Old 12-01-2018, 09:40 AM
  #275
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Our current wing, TKR5292, is not IFMAR legal. The wing on Ryan's car is not a HB, it's a proto wing from us that is IFMAR/ROAR legal. My understanding is that a lot of drivers run the AE wing on their cars, it's light and has less downforce and side support.
Matthew_Armeni is online now
Old 12-26-2018, 06:54 PM
  #276
Default Shock lenght
Hi i would like to know the lenght of front and rear shock,,,i need a set for my tekno nb48.3-4,i have build it from ground up and only thing missing me are shock and front ,rear drive shaft,,, i own couple other 1/8 buggy so if my shock on one are same as the tekno ,i will take them in waiting to buy the tekno one thanks.
kaven turcotte is offline
Old 12-28-2018, 01:11 AM
  #277
The shock shafts are 122mm and 137mm its likely that they are longer than anything you currently have. The Tekno buggy's have tall shock towers.
codysb05 is offline
Old 12-28-2018, 07:48 PM
  #278
Ooo ok so i will have to try to post a wanted in the classified ,,,so all tekno nb model have same size shock from nb 48 to 48.4??
Old 12-28-2018, 09:00 PM
  #279
48.3 and 48.4 use the same size shocks. Earlier versions use different shock lengths.
MX304 is offline
Old 12-29-2018, 01:20 AM
  #280
speedy2's Avatar
I meant Tekno has the longest shocks in the industry, so difficult to find other make that fit..
speedy2 is offline
Old 01-01-2019, 06:18 PM
  #281
Ok i will try to find the good one,,thanks for your helps.
And what are your diff set up for loose,dirt and kind ruff track and not too much big in size???i am looking threw here but i am looking to feed them soon,,i need some screw to begin my build and after begin building it,,,and any other tuning,tip,mods are welcome.
Old 01-02-2019, 02:18 AM
  #282
Trader Rating: 15 (100%+)
Any news on the 48.5?
mlax is offline
Old 01-02-2019, 09:04 AM
  #283
tobamiester's Avatar
Trader Rating: 300 (100%+)
Joe's Rough track setup maybe a good starting point Alum Servo Arm, Maybe center universals as basic upgrades.
tobamiester is offline
Old 01-02-2019, 09:07 AM
  #284
I'm sure there will be in due course. Some big races coming up , SIC in two weeks and obviously DNC in Feb. Tebo / Joe as I understand will be running the new car so potentially we'll all learn more
mlax likes this.
