Agama A215SV ::Official Thread::
#61
Has anyone tried or got any info on the new grey springs ?
#62
The new springs 94766/95766 (front) and 95878/94878 (rear) are a new optional spring, designed in mind for the A215SV. The new springs are slightly longer than the original black springs. These springs offer more support for the buggy, the spring rate on the front is harder than the original and the rear is compatible to the original.
#64
Hi all,
someone have a good astro Turf base Setup?
regards
regards
#65
@Mark Rumble
Thank you Sir.
Thank you Sir.
#67
bump
#68
Hi,
recentely I've bought an A215SV kit, and the problem with the rear hingepins still there... (agama reference 8227). They are a little sort, 2-3mm. In three days I have broken 2 rear antisquat-toe inserts (orange).
I've heard that the conversion kit includes new black hingepings, longer thant the old 8227 part. Why the unassembled kit doesn't include it? Wich is the correct size that have to have the hingeping to avoid the problem? There is another hingepin of other brand that fits correctly?
#69
Hi,
The SV kits and Conversion Kits (34001) now include the new (38227) hinge pins, the new pins are now of a 67.5mm length which solves this issue of the inserts breaking on heavy crashes.
If your kit has included one of the 8227 pins then this will have been from one of the early SV batches.
Mark
#70
Hi,
Mark
Mark
#71
This issue arrises from very very hard crashes, which we hadn't seen, not a known issue for many years ....the SV has been released 5 months. But regardless, the issue has been resolved and the replacement pins are available to your countries distributor.
#72
I've raced the A215 since it's release and I don't see where this is an ongoing issue. They had a batch of
Short pins on the SV. I noticed on the build and used pins from another manufacturer and cut them to fit.
Sometimes you need to think outside the box and be a little creative
#73
#74
[QUOTE=jubjub47;14909397]How foolish of him to prefer the kit came with the proper part
Where did you purchase the car? I will send you 2- of the corrected Agama pins free of charge. Use them in the rear.
#75
Hello all,
i have a generelly astro turf question. What is better to prevent grip roll?
A high upper rear link or a low one? i´m totally confused!
Cheers
Cheers
