Agama A215SV ::Official Thread:: >
Like Tree18Likes
Old 01-09-2017, 06:47 AM
  #46
Originally Posted by Holymoly View Post
So i can order the upgrade package in GB?
The conversion is just around the corner for the US, it will be worth the wait !
Mark Rumble is offline
Old 01-09-2017, 06:50 AM
  #47
@Mark
And for germany?
Michael
iwillresist2008 is offline
Old 01-09-2017, 07:34 AM
  #48
Originally Posted by iwillresist2008 View Post
@Mark
And for germany?
Michael
Hi Michael,
Please check with the German Distributor TQ Speed Shop.
Old 01-22-2017, 09:47 AM
  #49
Wich is the difference between a215 front sway bars and a215sv ones?
jeancc is offline
Old 01-23-2017, 01:34 AM
  #50
The shape of the sway bar is different, the A215 one bend parallel to the length of the car, but the SV one has a lesser angled bend at the end to meet up with the new sway bar link position.
Old 01-23-2017, 02:10 PM
  #51
Trader Rating: 14 (100%+)
Can anyone explain the advantage of using the standard (narrower) plastic rear wing braces versus the wider aluminum braces?
I know for a while on the Agama A8 and A8T, there were wider aluminum braces available, but the A215 and now A215SV are back to the standard size. Thanks.
robracing is offline
Old 01-23-2017, 02:16 PM
  #52
Purely preferencial, the alloy braces are just an old hop up part for the A8 and A8T as you say. The stock plastic braces work perfectly well so the team just use them, no change in performance.
Old 01-23-2017, 03:54 PM
  #53
YANMAN's Avatar
Trader Rating: 41 (100%+)
Has anyone had a chance to try out the new SV? I know Billy and the team guys have. I am looking for head back from the average Joe.
YANMAN is offline
Old 01-24-2017, 08:22 AM
  #54
Trader Rating: 54 (100%+)
Default First out with the SV
I had my SV out for the first time this past weekend. It was a cold weekend at the track, averaging just 45*F. I'd set the car up with my diffs the way I ran my A215 last summer (20f-3c-5r) and the suspension on the recommend US starting point setup that Billy T had shared. The colder temps and and much different and quickly changing track conditions than I normally ran had me trying many setup changes. I'll document my final setup this weekend. I know I moved the front shocks to the inner hole on the arm and went to red springs and moved the rear shocks in on the arm.
The car has great on power steering and turned well rolling corners but I was struggling with steering under braking.
I'm not an expert racer and far from a setup guru so I struggled some. Looking forward to getting the car out on my regular track later this spring for a real comparison.
This is where I started for suspension.
davinco is offline
Old 01-24-2017, 09:28 AM
  #55
underway's Avatar
Trader Rating: 52 (100%+)
try taking out some front brake to get more steering while braking.
underway is offline
Old 01-25-2017, 07:40 AM
  #56
Just made that adjustment last night.
davinco is offline
Old 01-26-2017, 03:00 PM
  #57
BillyT.'s Avatar
My setup from SIC. The under drive... I'm not sure how important it was to all of this. I used to run them all the time, then I didn't, and I never felt a real difference. If anything, it might help in bumpy sections, more than helping the car get out of a corner.
As far as how the car drove... I didn't feel like I could do anything wrong. Very easy to push.
Ultra Soft Cubez are on order, hopefully we have them soon.
The key to make this easy to drive I think, was going out on the inserts on the front. Widened the track by maybe 2 mil over all... had plenty of steering going in and perfect coming out... I think if I really leaned on it, it would push vs oversteer, which is just what an old guy like me wants.
Attached Thumbnails Agama A215SV ::Official Thread::-sv-setup-tylaska-sic-high-res.jpg
BillyT. is offline
Old 01-29-2017, 03:05 PM
  #58
blktransam's Avatar
Trader Rating: 59 (100%+)
Like any car really need to get a gallon on it before the car will gain traction IMO that's how the 215 was for me, going to be running my SV this weekend in Omaha it will be new so I am not expecting anything to be perfect hopefully get 1/2 gallon on it Friday during practice...
blktransam is offline
Old 02-09-2017, 07:35 AM
  #59
Sideshow Bob's Avatar
piosted this in the 215 thread...think these should be merged for simplicity
not mine but one of our team guys' cars:
PS: it's the AE b3 jconcepts body
SV ebuggy too:
Sideshow Bob is offline
Old 02-09-2017, 01:53 PM
  #60
mourinho's Avatar
Trader Rating: 46 (100%+)
and Kyosho MP9 Tki4 wing
mourinho is offline
