Like Tree24Likes
Sworkz S35-3
Old 12-18-2016, 11:34 AM
  #16
Lasse Poulsen's Avatar
What does the graphite reinforment help on the arms ?
Lasse Poulsen is offline
Old 12-18-2016, 02:35 PM
  #17
Trader Rating: 127 (100%+)
It's a tuning aid more or less.
Stiffer arm-less flex-more reactive-high traction smooth track
Softer arm-more flex-less reactive-low traction bumpy track
Looks like all of the arms will accept tuning plates.
ROSCOE is offline
Old 12-20-2016, 01:02 AM
  #18
So you are saying having carbon reinforcement (picture)
Will only be good for high traction track ?
But like most EU tracks are dusty, loose dirt track.
An none carbon insert is prefered ?
Old 12-20-2016, 05:17 AM
  #19
I would say it's a tuning option for feel. What I listed is probably considered what to expect through the different ranges of plates. You will most likely be able to run no plates, plastic or carbon. I'm not sure if it's doable but it looks like you could have to choice of an upper and lower plate as well. The options are not necessarily used by the book as we don't know how stiff the arm is bare and how stiff it becomes with plates until we start running them. I'm not saying your style track couldn't be ran with carbon plates but I'd start soft because I like a less reactive car while someone else may like the opposite and make it work.
ROSCOE is offline
Old 12-22-2016, 04:03 AM
  #20
pownabown's Avatar
The idea behind the carbon inserts is as mentioned to increase sensitiivity of the car and also to reduce grip.
If you run without the plates you get maximum flex and increased grip.
Running the plates the car looses grip in high conditions and also makes it more responsive in change of direction.
pownabown is offline
Old 12-29-2016, 03:30 AM
  #21
speedy2's Avatar
speedy2 is offline
Old 12-29-2016, 10:32 AM
  #22
Looking very nice !
Can you tell something about what upgrades are made
Old 01-03-2017, 08:49 PM
  #23
Originally Posted by HaulinBass View Post
someone should make a uhmw sheet for buggy chassis wouldnt have to be more than half a mm thick
Needs to be more then that. If there is anything hard, such as a pebble, the half a mm thick UHMW will tear.
EMORY46 is offline
Old 01-10-2017, 03:11 AM
  #24
Does someone have more pictures about that buggy? What I saw there is full adjustable lower hingepins like DNX8 and Tekno vehicles.
Bigbearfin is offline
Old 01-10-2017, 08:05 AM
  #25
YANMAN's Avatar
Trader Rating: 41 (100%+)
I wonder if Amain is even going to bring this car into the states. They already have the S35-2E on Clearance.
YANMAN is offline
Old 01-10-2017, 10:12 AM
  #26
It is suppose to be here soon. I'm sure the 2e will be a 3e shortly.
ROSCOE is offline
Old 01-11-2017, 11:59 AM
  #27
http://www.inforc.net/2017/01/exclus...os-al-detalle/
Old 01-11-2017, 02:07 PM
  #28
JCG
Originally Posted by Lasse Poulsen View Post
Alberto's car nice.
JCG is offline
Old 01-16-2017, 03:01 PM
  #29
whats with the extra large battery case?that takes up alot of room
stoney452 is offline
Old 02-06-2017, 09:16 PM
  #30
kja812's Avatar
Anyone else find it strange that SWorkz sent out teaser pics 2 months ago and now that the kits will be in stock by the end of the week, dead silence... searched and found a number of pictures on Facebook, team drivers appear to already have their cars in hand and built in the last week or two.
Also found a copy of the manual at http://answer-rc.com/en/6520-sworkz-...buggy-kit.html...pile of new parts, all the major components anyways. Changes to the driveline are, well, interesting.
kja812 is offline
