Hotbodies D817 Nitro thread >
Like Tree132Likes
Old 04-10-2019, 01:34 PM
  #691
Do you know if there are any other manufacturers cvds' or driveshafts that fit the MP9? I am looking for other Manufacturers cvd kits or driveshafts from other manufacturers that fit the MP9 wheel axles. I heard associated shafts fit the kyosho? or maybe the hot bodies fit?REPLY
Any help is greatly appreciated.
sn47som1 is offline
Old 04-10-2019, 01:48 PM
  #692
Default MP9
You might want to post this in the MP9 thread not the HB thread.
wreckingball is offline
Old 04-18-2019, 10:07 AM
  #693
I might want to?
Ohh cool, thanks MacGyver, so a lot of seasoned guys have run most of the platforms and know what's interchangeable and what's not.... so that means posting in multiple threads is what you want to do. Don't limit yourself! well i shouldn't even state the obvious that i posted in Kyosho threads..
So I take it that you don't have an answer to the question?
sn47som1 is offline
Old 04-18-2019, 11:34 AM
  #694
I might want to?
Thats no problem Bilbo baggins,i have no idea about anything to do with Kyosho as i only run HB cars now days. Did try Kyosho but binned it after 2 race days,not my cup of tea old boy.
Old 05-02-2019, 09:22 AM
  #695
I have bought my first HB car,a used D817.I was told that there have been issues with the stock center spur gear breaking.Any more information on this?Is the new model's part compatible with the old car?
Kibble is offline
Old 05-04-2019, 11:40 AM
  #696
Kibble is offline
Old 05-05-2019, 11:36 AM
  #697
im running my 1st shipment 817 and original spur with no issues
RePeTe is offline
Old 05-05-2019, 03:02 PM
  #698
Is this normal when running the 3 dot b plate?
shark2288 is offline
Old 05-17-2019, 04:48 PM
  #699
Can one of you HB gurus kindly measure in mm the length of an 817 or 815 wheel driveshaft or let me know what it is? Thanks
sn47som1 is offline
Old 06-03-2019, 08:48 AM
  #700
Trader Rating: 25 (100%+)
Does anyone know if the D819 transmission conversation really works? I've been looking at it and it looks essentially the same thing as what it has now just more parts. All it is 2 pieces with a pin and a set crew with smaller bearings. How does this free up the driveline?
arm2storm is offline
Old 06-03-2019, 12:44 PM
  #701
there is no set screw. but I also don't really feel any difference. I bought only because I need to replace the front drive shaft so figured I would do the upgrade. I wasn't too thrilled with the small bearings, as the original setup had nice big bearings that last forever.
RePeTe is offline
Old 06-04-2019, 12:05 AM
  #702
Default Transmission conversion.
Ive put it on my car and it definately frees up the drive train. The major change is the pinion gear is straight cut,its not a day and night change but the car rolls better and carries a touch more corner speed. Also the acceleration is slightly better.So its a minor change but add it with the other changes like the thinner hubs and the new B plate and the rear camber link holder the car becomes more aggressive and turns better. For me i was unsure at first but now ive made a few changes im more consistent and im a good half second a lap quicker.
Old 06-10-2019, 01:43 PM
  #703
I am trying to set rear shock length on the V2 car to what is advised on the standard setup sheet but it looks that axles will get out from the diff cups,any tips?did you have similar issues?
Kibble is offline
Old 06-18-2019, 10:36 PM
  #704
omarwashington's Avatar
Maybe try 44 mm shock length for the rear?
omarwashington is offline
Old 07-06-2019, 09:13 AM
  #705
Best place to buy the new HB nitro buggy for decent price?
KeeneRc is offline
