Hotbodies D817 Nitro thread >
Like Tree118Likes
Old 06-14-2017, 11:50 AM
  #256
lilstewie's Avatar
Originally Posted by Chad Phillips View Post
diff weights have nothing to do with the new pitch. that is just from testing.
Thank you for all the information.
lilstewie is offline
Old 06-14-2017, 01:22 PM
  #257
no problem.
Chad Phillips is offline
Old 06-14-2017, 01:35 PM
  #258
Originally Posted by brokenmoto View Post
Will the pre drilled holes on the kyosho wing line up with the d/e817 wing mount? Need a new wing. All i've used were proline so far. Time to try something different.
Nope at least not the Kyo's wings available at my LHS
chongo is offline
Old 06-14-2017, 01:47 PM
  #259
That is the wing that we run and all you have to do is squeeze the mount together just a tad and it works perfect... Been running it a while.
twigstoy is offline
Old 06-14-2017, 05:41 PM
  #260
Sorry if I gave miss information. The ones I looked at were off more than a tad.....
Thanks for update.
chongo is offline
Old 06-14-2017, 09:14 PM
  #261
wydopen's Avatar
just enlarge the outside of the holes a bit with body reamer..also grind off the lip for recessed holes with a dremel so wing buttons sit flat..I dont like squeezing the wing mount together
brokenmoto likes this.
wydopen is offline
Old 06-19-2017, 09:34 AM
  #262
Default Information
Just for those who don't like the slop in your D815/17 I have a solution,I've fitted the serpent front end on my car that's caster blocks on the front direct fit & all ball joints & track rods front & rear ,you have to run serpent axles & 96mm driveshafts up front 98mm are standard but to me were a little deep in the outdrives & I was a little worried of a blowout when the arms flexed ,but ......after a good few meetings & test days hardly any slop whatsoever,it might not bother some but i know it bothers others
MrMike1968 is offline
Old 06-19-2017, 12:25 PM
  #263
Torrance designed the car with the slop in it... It so the suspension stays free if dirt gets in there.. no need to try and fix it.
Old 06-20-2017, 01:55 AM
  #264
Thats a lot to do. Give this a try. It works very well.I put to 2 per wheel.
https://thequagraine.com/2016/08/23/get-rid-of-slop/
bretto107 is offline
Old 06-20-2017, 05:15 AM
  #265
Default Information
Yes ...granted it is a lot to do & as I tested the serpent I was looking at both cars side by side one day & said ...'hang on' & when I got started I couldn't Finish until I had it all & eBay was visited like a best friend,I'm sure there's easier & less expensive ways but I went this way & thought I'd share ,the cars top notch & although I've been offered other cars to 'try out' what's the point as I always come back to HB
Old 06-20-2017, 06:20 AM
  #266
of course you are free to try whatever comes in mind, but the point is, slop is not only wanted/accepted its needed in 1/8 off road.
car is super slop free and tight on the bench will stop working on a dusty track and feel wrong after 5 minutes in.
you want a car working all trough the long , dusty mains.
gt racing is offline
Old 06-20-2017, 03:36 PM
  #267
Trader Rating: 126 (100%+)
Neesh is offline
Old 06-21-2017, 04:50 AM
  #268
pl_unc86's Avatar
Trader Rating: 17 (100%+)
Just picked up a D817 and D8E17, anything I should know before starting the build?
pl_unc86 is offline
Old 06-23-2017, 03:54 AM
  #269
pl_unc86's Avatar
Just making sure...
The stock kit comes with the gold front springs and yellow rear? The standard setup says yellow front and blue rear.
pl_unc86 is offline
Old 06-26-2017, 12:46 AM
  #270
Originally Posted by pl_unc86 View Post
Just making sure...
Personally I used longer screws in the front and rear center diff chassis stiffeners. My steering servo bottomed out on the chassis so I raised it up a couple mm(servo touches chassis it's toast).I'd use loctite on anything metal to metal. Get about 10 packs through it before messing with set-up. The only thing i've had a problem with is the center chassis stiffeners coming loose and or breaking bolt or ball(the 30 ft double on my track may be a little much). All in all I love the car, sooo much fun! Ohh you may want the other springs you mentioned, I already had them for my d817. I haven't tried the car with stock springs, you never know.
brokenmoto is offline
