Hotbodies D817 Nitro thread >
Like Tree132Likes
Old 04-30-2017, 11:21 PM
  #196
stanleyw808's Avatar
Hello TRIN and Friends,
I also had a thought of going this way by using Front Truggy Shock Shaft and Longer Shock End.. But after some careful thinking, we will then face with Ride Height problem.. The "Short Rear Shock" configuration already have a bit of a problem if we want to set lower then 27mm. But I don't know if this is happened to other fellow as well..
Up travel would not be a problem I think..
Cheers..
Originally Posted by TRiN View Post
Have you tried using the (longer) D8T truggy shock ends to get back some downtravel? Obviously you would lose overall uptravel...
https://www.amainhobbies.com/hb-raci...bs67820/p55536
stanleyw808 is offline
Old 05-01-2017, 10:07 AM
  #197
omarwashington's Avatar
I still have the D815 but looking to up grade my chassis to the 17. Do I also need new diff cases? I do know that I will need the new side guards.
omarwashington is offline
Old 05-01-2017, 10:40 AM
  #198
Trader Rating: 128 (100%+)
no you don't need the diff cases. Only difference on the diff cases are the new bigger bearing on the inside for the pinion.
you will need a new D block though, well not necessary as the 815 block has the notches on it to lock in to the chassis but should still fit the 817 chassis. Geometry is the same but now you can get it in finer increments
Neesh is offline
Old 05-02-2017, 05:08 AM
  #199
Rcrenew's Avatar
RCRenew HB Extended lower engine mounts back in stock.
RcRenew.com Engine services and hobbies RCR Mods Rc mods engine mods
Attached Thumbnails Hotbodies D817 Nitro thread-hotbodies-d8-d8t-extended-engine-mount-1.jpg
gilbertfg and wydopen like this.
Rcrenew is offline
Old 05-06-2017, 11:34 PM
  #200
ravage's Avatar
Trader Rating: 15 (100%+)
Was going to go with the kyosho car but going with one of these now. How's the stock set up will I need anything?
ravage is offline
Old 05-07-2017, 07:31 PM
  #201
Just the aluminum servo horn.
Eastside777 is offline
Old 05-07-2017, 11:14 PM
  #202
Car is awesome out of the box. Aluminum servo horn. And maybe #4 rear carbon camber plates. Down the road you may want to try the short rear carbon tower with truggy front shock bodies. Love it on my car
SupermaxxRich is offline
Old 05-08-2017, 08:36 PM
  #203
imaxx21's Avatar
sir, please settle down
imaxx21 is offline
Old 05-09-2017, 01:19 PM
  #204
you still alive???
Old 05-10-2017, 05:28 AM
  #205
Apco1's Avatar
Anyone know where to get the 114754 Shock bladder? Out of stock everywhere I've looked.
Apco1 is offline
Old 05-10-2017, 07:51 AM
  #206
Search - Answer RC Ltd.
Old 05-24-2017, 05:19 AM
  #207
i dont know if you still need them but i have them in stock.
https://www.absolutehobbyz.com/Hot-B..._p_506777.html
Chad Phillips is offline
Old 05-24-2017, 06:47 AM
  #208
Bladders style or Emulsion style when building shocks? If using Emulsion what o ring are u using?
Old 05-24-2017, 12:05 PM
  #209
Bladder
Old 05-24-2017, 12:06 PM
  #210
Emulsion on 1/8th scale?... cut the center out of a bladder.
Sofa King is offline
