question on solvent sprays for cleaning
Do you know any solvent spray that can be used to clean cars that does not leave any residue? most leave some type of sticky residue that may or may not harm surfaces.
Simple green
The flashpoint cleaning spray is basically the best stuff I have found yet. I use to stick to simple green / WD40 but now if I can I won't use anything else. It's really damn good.
http://flashpointrc.com/flash-point-...cleaner-32-oz/
I recently even did a 60/40 mix with water and used it in an ultrasonic cleaner I got off amazon for cheap and it was amazing. No more scrubbing shock body threads to get them clean. 5 min in the cleaner and they looked basically brand new.
Most of you suggested water-soluble agents.Do you take the car apart before using them? What about rust?
I pull my radio tray, motor and tank. Soak it with simple green and hose it off. Always looks great and dirt doesn't stick to it!!
Here's an in progress shot of my Mbx7r. Look at that shine from just simple green and water! Oh and I let it dry by just sitting it out in the sun and letting the sun bake it. Always comes back looking like new!
Have you ever tried washing axle grease off of your hands?
Pack your bearings with marine grease and you can pressure wash the car with little worry. Bearings really aren't a huge deal. I often get a dozen days of use out of my wheel bearings, diff bearing can last much longer.
CVD's are the only major problem. Those need relubed if they aren't booted. But that's normal.
I suppose you'd only do it if the car is so muddy and dirty that you absolutely have to use water. And most cleaning solvents/de-greasers seem to contain water anyway...
Diltued simple green for the car. Clean and dry well, and then a bit of WD40 on a rag for metals.
Endust or other furniture polish (Dollar Tree brands are nice) at the track.
Nope. No rust issues. A little surface rust on the drive shafts where it rubs the cup but that comes off with just a while down lol
For me, it depends on how my truggy and buggy look after a race. I race weekly and the heat line up changes depending on the turn out. We usually run a watered track, but not after each heat. So, if they come home pretty dirty, i'll pull off the arms, electronics and motors, spray everything except the motor and electronics with simple green and give them a brushing with a simi stiff brush, and blow it off, then spry off with wd40 and blow it off again. Spray the body with sc1. Done. I replace the bearings once or twice a year depending, and make sure the cvd's are greased lightly. Never any rust.
