Pit Trailer Flooring >
Old 10-23-2016, 05:53 PM
R/C Tech Elite Member
jkas10's Avatar
Trader Rating: 123 (100%+)
Default Pit Trailer Flooring
Hey all. I am upgrading the inside of my pit table. I have pulled the bench and cabinets out and am going to insulate the walls, paint, and then cover the wooden floor with ??? I am thinking vinyl would probably be fine for the interior floor. Thoughts? However, vinyl is probably too slippery when wet to use on the rear door. All good suggestions are welcome.
jkas10 is offline
Old 10-23-2016, 06:08 PM
Thrifty's Avatar
Lowe's has some nice stick on vinyl planks and also some interlocking waterproof planks that you wouldn't have to stick on..
Thrifty is offline
Old 10-24-2016, 05:58 AM
Frank L's Avatar
Trader Rating: 148 (100%+)
I have hard wood in mine which works well but I think I would use this stuff it's called G Flooring.
http://m.homedepot.com/b/Flooring-Ga...5yc1vZb97tZank
Frank L is offline
Old 10-24-2016, 07:14 AM
Zerodefect's Avatar
The vinyl and fake wood I've seen in trailers has been super slick ever time it rains or is humid. Even the Rino liner and sand mix gets slick.
If I had a trailer, I'd put that really cheap industrial hallway carpet in it. Tear it out and replace it every winter as needed. Nothing slides around on that stuff.
Zerodefect is offline
Old 10-24-2016, 08:00 AM
I personally would go with a 1/2 to 3/4" rubber floor. Easy on the back when standing, good traction and no scratches and easy cleaning by taking a hose to it after a race weekend. You can buy it in 2'x2' sheets. Very long lasting as weLL.
flap jack is offline
