Like Tree13Likes
Agama A215T
Old 01-28-2017, 06:05 PM
  #61
Originally Posted by saw View Post
i do not use those brake guides not necessary
I put them on and then noticed the discs are not in alignment if you use the guides so off they came. You cannot use the guides with the kit brakes.
windellmc is offline
Old 01-28-2017, 06:10 PM
  #62
Trader Rating: 126 (100%+)
The guides are for the old pads and discs which were much narrower being a fiber disk and metal pad only.
The kit supplied brakes use to be option parts.
ROSCOE is offline
Old 01-29-2017, 10:50 AM
  #63
jazjato's Avatar
Truggy now available on amain hobbies. Qualifies for Jan25 coupon code as well.
Just glad to see it now available.
jazjato is offline
Old 01-29-2017, 05:11 PM
  #64
Trader Rating: 26 (100%+)
Saw their price and I am glad I got it from Billy. Thanks again for the hook up.
go4broke is offline
Old 01-29-2017, 05:17 PM
  #65
LOW ET's Avatar
Trader Rating: 103 (100%+)
THIS!!!
LOW ET is offline
Old 01-30-2017, 01:29 PM
  #66
LOW ET's Avatar
how much droop are you guys running front/rear?
LOW ET is offline
Old 01-30-2017, 06:03 PM
  #67
All of it. I moved the front shocks to the inside hole on the arms and tower.
Old 01-31-2017, 12:44 PM
  #68
LOW ET's Avatar
but how long is your shock?
LOW ET is offline
Old 01-31-2017, 04:55 PM
  #69
I didn't even check. I just made sure I took enough droop out to protect the shock caps and ends. It looked about right.
Old 01-31-2017, 04:57 PM
  #70
Does anyone know what the caster is in the stock hub carriers? I saw there are 12 and 16 degree aluminum ones for the a215.
Old 01-31-2017, 05:13 PM
  #71
That's what I did...
go4broke is offline
Old 01-31-2017, 05:24 PM
  #72
LOW ET's Avatar
front is 12*
LOW ET is offline
Old 02-02-2017, 03:55 PM
  #73
Trader Rating: 27 (100%+)
anybody got a215T e-truggy without body and i like to look at it ? thanks
taztal3 is offline
Old 02-10-2017, 06:51 AM
  #74
Loving the truggy so far. I had put in 8x1.3 pistons and everything else is box setup. Truck is still loosening up. Able to drive more aggressively during each outing.
go4broke is offline
Old 02-11-2017, 02:26 PM
  #75
LOW ET's Avatar
how are you guys trimming the front of the body? like the box art cut job or on the molded cut line?
LOW ET is offline
