When is new Tekno NB48.4 coming out?
#16
the point about choosing the right car for you is to keep it a long time
the longer you keep a buggy the faster you become.. once you're used to a car you stop thinking too much about it and focus on driving
so yes at the start the choice does matter.. I always advice to buy a buggy that you'll able to improve through the years.. from a brand that is NOT redesigning everything all the time
#17
Yet the D8 was World Champion against the MP9 TKI and finished second position the next WC. Short arm suspensions work good in less conditions than long arm suspension designs and require different tuning technique (they naturally roll more, making them suited to lower grip tracks) but on a track with a very mixed layout it's a wash. No buggy works good 100% of the time. That's why we that run older platforms rely on luck most of the time
30Tooth, I read your previous post about the short vs long arm suspensions having more of an impact that pillow ball vs. C-hub / C-link.
I believe you categorized the Losi and the Mugen as short arm setups and the Kyosho and Hot Bodies as a long arm setup.
Please correct me if i'm wrong, where does the Tekno NB48.3 land? That new Serpent SRX8 looks great too - however I cannot tell if its short or long arm based.. its definitely C-hub.
Thanks again, Jeff Check
#18
The longer the arm the stable the car is, then there's the cars with longer front arms than rear arms, like THE Car, the MP9 and possibly the MBX7 and the Losi which feel somewhat faster to drive.
Unfortunately I don't know much about teknos specifically but this post should help you, if you are interested in more just ask.
#19
The tekno is a Losi style c-hub and therefore short arm. If there's an outer hinge pin like the Hot Bodies D8 then it's as short as the arm can be, if the steering block is screwed to the arm like the JQ THE Car and X-ray XB9 it's medium length and if the c-hub has the outer hinge after the steering block screw like the new Serpent, the Kyosho and the D815 it's long arm. The Mugen style is related to the medium length arm.
Then you have the obvious point, world champions don't care - Tessman, Tebo, and Boots long arm, Lutz and Maifield short arm, Cavalieri and Ronnefalk medium arm pillow ball..
So all are ripper fast if need be is just what is your preference I guess. And from an engineering perspective the long arm seems to be most advantageous and most expensive to manufacture.
#20
http://stories.jqracing.com/white-edition-explained/
About half way down the page is good description of what is being discussed here
#21
I would like to see how well a pillow ball suspension would work on a narrow platform like the Tekno.
#22
#23
The Kyosho is pretty much basicly the same car as it was in 2008 when the MP9 first came out, although they have made numerous tweaks to it. Seems to work.
Mugen - again a case of, small tweaks, small updates.. still same general car as three years ago.
The general rule of thumb with the 1/8 cars is a car platform usually tends to last about 4 years.
As for the long arm vs short arm, I always felt like the cars that had the short rear arms with the wide centre mount gave a different driving sensation, more of a twitchyness and less stable, and you have to get on the power more smoothly or they'll suddenly release.
I think this can easily be explained by looking at a long arm and a short arm car from the rear, then grabbing the rear wing/mount and twisting/rotating it. You will then see that the short arm car when rolled, induces a large height difference in the arms. Which is probably what causes the much more sudden release.
