Serpent SRX-8 Nitro buggy >
Like Tree75Likes
Old 02-14-2019, 03:20 PM
  #766
Chad Millikan's Avatar
Originally Posted by Big Will View Post
Are there any non-Serpent brand clutch shoes that fir the 4-shoe clutch? The Serpent ones are hard to find.
losi works
Big Will likes this.
Chad Millikan is offline
Old 02-14-2019, 04:00 PM
  #767
Wow did I read that wrong!!! reading comprehension is a 0.0
I bought the Tekno RC clutch and spring hardware kit to see if it worked with the Serpent clutch shoes etc.
https://www.amainhobbies.com/tekno-r...kr5353/p273670
it did, springs work too as well as the clutch screw, yet it is narrower head on the pin than the Serpent
I assume the Tekno clutch shoes should work as well.
In case you still looking for Serpent shoes. AbsoluteHobbyz has them in stock
https://www.absolutehobbyz.com/Serpe..._p_488314.html
sebtarta is offline
Old 02-16-2019, 08:53 PM
  #768
How often are you guys changing clutch bells and spurs? Mine seems a lot looser than I usually set other cars
Soyer is offline
Old 02-16-2019, 10:43 PM
  #769
Never have
Old 02-17-2019, 03:09 PM
  #770
Trader Rating: 14 (100%+)
To tighten up the mesh you want to mount the motor mounts to the chassis and then put the motor on from the top. Keep the screws a little loose and twist the clutch bell towards the spur gear and tighten it down. This is the way you can tweak the mesh a little.
IOP_Racer is offline
Old 03-04-2019, 01:05 PM
  #771
Default Serpent SRX8 EVO.
Hi guys.
I'm thinking about this buggy and I've wanted to know the pros and cons.
What should I be aware of.
Hop ups?
Anything that you feel is a good thing to know, before I get one.
Hit me.
MikeMikeMike is offline
Old 03-05-2019, 07:50 AM
  #772
There is a thread on the SRX8 with lots of info.
But the car is very durable. it all really depends on the driver. Just as with any other car.
Hop-ups? Do you need them? No. The EVO has most of the latest parts already as well. Maybe extra suspension arms, sway bars, springs, shock pistons.
Other than that, replace parts as they break or get worn out, example bearings.
J.Whiting and MikeMikeMike like this.
sebtarta is offline
Old 06-06-2019, 08:45 PM
  #773
Sorry to say and mean no offense but this is what happens when you learn to design in a Crackerjack box.
Do you really think that engine manufacturers control tightly the tolerance between the motor mount holes and the end of the crankshaft? No because all cars have adjustable gear mesh...Well no...Not this one. If engine manufacturers had to control that tolerance tightly, the engine prices would increase.
Out of 3 motors, even by removing all threads on the part of the screws that are going threw the motor (about 5mm below the head), making the diameter of the screws smaller to give more play, 1 fits well, another fits too loose and the other, I would not even last 1 lap and the gears would strip..
We're talking 3 Novas
Plus, it make fine tuning gearing a pain, not being able to change only one component and the ratio cannot be adjusted as finely.
Sorry for the rant, and don't get me started and the small pinion gears that don't engage fully with the planetary!!!
Unless someone points me to an adjustable engine mount, I will design and make my own.
But otherwise, like the car
alex_blais is offline
Old 06-06-2019, 08:51 PM
  #774
Super Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 61 (100%+)
Sorry your having issues.. i run novarossi in my buggy and gear mesh can be set.. currently run the mephisto in the buggy.. i do run a kyosho clutch setup but a 13t clutch bell.. im old school and just like 3 shoe clutches.. also i ise the 1 piece engine mount also but either set up i can get the mesh set up properly. 46t spur gear which is factory. If you want to chat send me a pm. Jeremy
J.Whiting is offline
Old 06-07-2019, 05:49 AM
  #775
savage24x's Avatar
Are you using the serpent clutch bell? Billy made all clutch bells the same diameter for this specific issue. I haven't tried, but maybe the 811 engine mounts will work? https://www.ebay.com/itm/283445853498
Can you get me the measurement of distance between the mount holes? I can verify tonight.
savage24x is offline
Old 06-07-2019, 06:19 AM
  #776
Thanks, I tried a one piece mount from my 811v2 and does not fit. I'll make my own. The 2 piece mount does not work either
Old 06-07-2019, 08:15 AM
  #777
Super Moderator
J.Whiting's Avatar
SER600839 is the mount I use. mephisto. mantra and p5 gear mesh all lines up well
Old 06-07-2019, 08:24 AM
  #778
Super Moderator
J.Whiting's Avatar
also if possible post a few pics of center diff and gear mesh.. just curious on things..
savage24x likes this.
Old 06-07-2019, 09:12 AM
  #779
I've never had an issue with gear mesh and all I've ever ran in my buggy were Novas. As mentioned earlier are you using the serpent clutch bell? The bells were designed with the understanding that the motor mount doesn't move.
Also which version of the kit are you running? I know it was a running change on the evo to move the motor slightly closer to improve gear mesh but were talking only 1mm at most.
BHutch is offline
Old 06-07-2019, 12:31 PM
  #780
I bought the srx8 non Evo from a fellow racer. Clutch and spur are per spec and genuine serpent and correct part numbers. Like I said, most will be ok but occasionally the outside casing of an engine is not perfectly aligned with its internals and this is what happens when you have a non adjustable mesh. Thanks for the inputs guys
