Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#91
Well...it's nearing that time when I need to refresh my current buggy after 3 seasons. I have always liked the Kyosho, but was always partial to Mugen as early as the MBX4 series. I might be jumping ship to this new buggy.
#92
#93
Ive run AE, and JQ.. recently stepped up to the TKI3.. I cannot believe how much steering this thing has.. you just brake,turn,and pull the trigger.. its unreal.. and they have improved it with the tki4? how lol.. i have some kits on order.. cant wait..
#94
Hi Guys, is there a list of the versions Kyosho use? I have a MP9 Nitro which I used for my first race last year and no idea what version it is etc, I got it as new unused but with no lid. Loved my first race and it's OS engine went well, now looking to get a MP9e for this season, but wondering about all these version, I assume reading this, TK14 is the latest but then I see the different versions in Inferno, readyset and competetion options, now the comptetion version is over £600 in good old England so that's really not an option but was thinking of the readyset version and then gradually adding some upgrades?
2nd Question please is, will a single 4s 5000mah batteries fit in ok, I have a bunch of them from a TT EB4 G3 which I thought was really good and strong, so don't want to fork out for 2s ones?
#95
#96
Long rear tower (8 holes to adjust roll centre)
Long rear shocks
Battery box with waffle lid mounted at rear of buggy next to engine
Velvet coated shock bodies F/R with plastic clips to adjust ride height
Purple springs
Hard coating on all aluminium parts
Plastic radio tray posts
Cross drilled disc brakes
Long shock cap
Hard anodized balls all round
2.5F and 2.8R roll bars
MP9 TKI2 main updates:
Short rear tower (10 holes to adjust roll centre)
Blue springs F/R
Med length rear shocks
Gunmetal coating on all aluminium parts including shock bodies
Threaded spring adjuster shock bodies F/R
Aluminium +2mm rear hub carrier
Aluminium radio tray posts and wing stay post
Aluminium rear toe in block
Solid brake discs
Short shock cap
Revised low force shell
Optional carbon front battery mount
Steel balls all round
2.3F and 2.5R roll bars
MP9 TKI3 (as TKI2 above plus changes below):
Revised radio tray/forward battery box/rx box
HD UJ shafts all round
Optional forward cab shell
MP9 TKI3 spec A:
As MP9 TKI3 kit but factory assembled, then checked by Yuichi Kanai.
MP9 TKI3 readyset:
Factory assembled RTR buggy using plastic parts from MP9 TKI3 kit but using cheaper produced aluminium parts e.g shock towers 3mm stamped aluminium with minimal adjustment compared with the MP9 TKI3 kit's 5mm machined 7075 aluminium shock tower.
Differentials also missing 2x bevel gears and 1x cross pin
UJ shafts only on front
Spiral cut Crown and pinion gears (MP9 TKI3 kit has straight cut Crown and pinion)
#97
Pick yourself up a used TKI3 and you'll be set, theres tons out there with the TKI4 coming soon.
#99
#100
https://www.youtube.com/watch?v=C3usmUm6n7E
1:27 -> Jared Tebo with the TKI4 at Silverstate
#101
He really gets that MP9 turning in the air well.
#103
Thanks All !
