Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#991
#992
I built mine with the 19's ran it for a couple months and was great but then i found myself trying to get more steering in certain races. Went to the 16's and so much more versatile for me. High speed long sweeping turns the 19's work great..if you have a couple 180 turns then the 16's and the 13's are going to be better. I chose the 16 because we still have the pills that go either at a 0 or + or -
#993
#994
Hello, I am new to the forum, I am from Argentina, I have a kyosho mp9 tki4 motor use novarossi mito4 servos savox 1267 and radio futaba 4px,
I had the model tki3 before, and I put the front of aluminum of 13º and the truth that I left of doubling, I ran with the akerman everything for the front and the caster also, excuse my English since it is translated by google tratuctor
Now I wanted to ask and some told me to buy the one of 19º others of the 16th, I wanted to know what experience I could get from you, and I wanted to buy the shock tower MS that are for tracks with little grip, like the ones I run, I wanted to know if Some of you could try them and if they really go better than the originals
I tell you my set up I can have something more too.
Shock silicone rear 500 spring orange front blue spring 550
5 bolts.
5000 5000 3000 differential silicone
1 degree divergence front
2 of combo front
3 degrees rear convergence
3 camber rear
In the rear tower seized in the most remote place and down
On the bottom grill I grab below and inside
And in the front part sticking in
I do not know what else to explain, or to modify it so that it improves with clues with little grip and now improve the subject of the direction that with the piece of 13º bend little ..
Change the stabilized bar I have from 2.3 forward and back
Thank you in advance.
5 bolts.
2 of combo front
3 camber rear
#996
I got the body of the shock absorbers but I did not find the longest rod, or just changed the body? And the piston does not reach the top.
#997
this is a setup posted by Shanef a few pages ago, it is very similar to what i run and is an excellent low grip setup.
#998
My idea/understanding is: 13's are too twitchy, 19's are for large/rough tracks, 16's are for general usage.
Regarding droop: what is normal lenght for fr and rear unmounted shocks? From center of cap mounting hole to center of bottom ball? I'm guessing that i've screwed shafts too tight into lower plastic end.
#999
KYOIF485 tower and the shocks are KYOIF484
#1001
Do you know if KYOIF484 shocks comes in the tki4 kit..
What suspension shocks will I need for my
front tower If485 and my
rear shock tower ifw408b
For my tki4
Or am I better off on buying the
Kyosho Hard Front "MS" High Camber Mount Shock Tower ifw465
For my tki4
#1002
Thank you very much for the help..
And with respect to ifw436 or ifw461 I use the 13th of the tki3 and the truth does not bend the car at all ... very little
#1003
IFW465 The Kyosho MP9 TKI4 Hard Front "MS" High Camber Mount Shock Tower is an optional high mount tower. The mounting holes are set 2mm higher to deliver faster corner speeds. This tower is taller than the "S" High Camber Tower and best suited to low grip, rough surfaces. This tower must be used with the High Mount Upper Suspension Holder (KYOIFW466).
#1004
Or will I need bigger suspension?
Don't know if I should get the H-S if464 Or HMS if465 shock_Tower
And will I need if437
For the rear Tower?
Or the if408 rear tower
Just trying to find out what's the best Hard Anodized Tower to use
If someone can help me with this information
