Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#947
btw, what is a working droop range both F and R for stock shock package (S and M acc.)?
#948
#949
Hi, could someone find the part numbers for the spurgear on the centerdiff on the TKI3 rs model? Is it the same as the TKI3/4 version IF 410-46
I know they will crossfit, but need the partnumber from the TKI3rs manual. Diffs on ebay for the RS is bery cheap if the spurgear is the same.. :-)
#950
Center Differential & 46T Spur Gear
Kyosho Inferno MP9 TKI3 RS
http://www.dollarhobbyz.com/collecti...-46t-spur-gear
46T Spur Gear (Part # KYOIF401-46)
Hardened Steel Construction
Two (2) Differential Shafts (Part # KYOIF413)
Two (2) 8x16x5mm Metal Shield Bearings (Part # BRG005)
Differential Case and Gasket Set (Part # KYOIF403)
Two (2) Differential Bevel Gears and Washers (Part # KYOIF402 Partial)
Two (2) P6 Silicone O-Rings (Part # KYOORG06 Partial)
Differential Bevel Shaft (Part # KYOIF411 Partial)
Four (4) 3x10mm Flat Head Screws (Part # KYO1-S33010 Partial)
MP9 Center Differential
Center Differential
Two (2) Center Differential Shafts (Part # KYOIF413)
Two (2) Shielded Ball Bearings 8x16x5mm (Part # KYOBRG005)
Differential Case Set and Gasket (Part # KYOIF404)
Differential Bevel Gear Set (Part # KYOIF402)
Two (2) Differential O-Rings (Part # KYOORG06 Partial)
46T Spur Gear (Part # KYOIF410-46)
Differential Bevel Shafts (Part # KYOIF411)
Four (4) Case Screws
http://www.dollarhobbyz.com/collecti...r-differential
#951
#952
Center Differential
Center Differential
#953
I googled IF403 also, it seems that it is the old small volume diffcase from Mp7 and 777 series. So, the picture in the Dollar ebaylisting is not correct either. Does the TKI3 RS have a small or large volume diffcase? All pics i can find online seems that it has a large volume diffcase like the MP9 TKI3
#954
#955
Anyone else had an issue with the exhaust pipe wire breaking?
#956
yes plus the pipe hanger holder is an odd size so you have to drill it out to get anything bigger than the Kyosho wire to fit. I spotted this on Elliott Boots car in an under the hood on Neobuggy and its the same one i have been using for more than a season and 2 kits later still good to go:
Its an Ofna pipe hanger and they are discontinued but Traxxas has something similar for the Tmaxx i think.....i would have to check the shop but im out of town till sat. Just bend to fit use a lock nut and no more broken pipe hangers or melted tanks anymore and keeps the pipe straight. I also use the Kyosho white pipe support to keep the pipe from hitting the mud guards
#957
And there is the exploded view of every car there is. And the spur gear is the same on all Mp9.IF410-46
#958
#959
So, can anyone confirm if the LFR body for the MP9 will fit this?
