Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#796
Lol the inline fuel filter isn't really a filter at all just a place to hold extra fuel. If anything is small enough to make it through the brass filter in the tank a little mesh screen isn't going to stop anything.
I stopped running them altogether as it's just another spot a leak or failure can happen
And about losi filters: i already have Outerwears prefilter (and some new filters) for that barrel type of filters, and i don't want to throw it away and spend extra ~20 bucks for Kyo-style prefilter. TBH i think L-style air filter gonna be industry standard in next few years (like 25T spline for servos becoming now).
#798
Another question:what about kickup/caster on TKI4 vs TKI3?
From what i've found here and there (may be completely wrong):
- Stock TKI3 kickup w/inserts: 11deg, have no idea what range inserts could give
- Stock TKI4 kickup w/inserts: 5 deg, no idea
- Stock TKI3 & 4 hubs - 13 deg, w/ +1 and -1 adj.
- Option alu hubs: 16,19 deg., w/ +1, -1 adj.
And finally, conclusion about using 19deg. blocks along with TKI4 B-plate
#799
A TKI4 with 19* hubs have close actual caster as a TKI3 with the 16* hubs, provided both use the base setup. The kick up inserts produce 2* of change depending of the direction, so 9* and 11* on the TKI3 and possibly 9* and 6* on the TKI4.
Last edited by 30Tooth; 12-07-2016 at 06:37 AM. Reason: Corrected TKI4 angle mistake
#800
Originally Posted by AZRC4Me View Post
If you run 9deg kickup w/ -1 caster on the standard knuckles, you would have 9+13-1 = 21deg total caster. Here are the different caster setups you can run:
9° Kickup / 13° Knuckle / -1 / 0 / +1 Knuckle insert = 21 / 22 / 23 total caster
11° Kickup / 13° Knuckle / -1 / 0 / +1 Knuckle insert = 23 / 24 / 25 total caster
9° Kickup / 16° Knuckle / -1 / 0 / +1 Knuckle insert = 24 / 25 / 26 total caster
11° Kickup / 16° Knuckle / -1 / 0 / +1 Knuckle insert = 26 / 27 / 28 total caster
And no, the car will not handle the same if you run different kickup but still have the same total caster.
Here's a chart showing what possible caster setups you can run with the MP9 front geometry. These will all have different handling traits, meaning just because your total caster is the same doesn't necessarily mean it will handle the same. Box stock is the following:
11° Kickup / 13° Knuckle / 0 / Knuckle insert = 24 total caster
#801
So do you take off - 2 for Tki4 front kick up?
#802
So, looks like pure _base_ kickup (w/o inserts) is 10deg. for TKI3 and 6 deg. for TKI4, giving us 9/11 and 5/7 hingepin kickup.
There we have:
- 9/11 plus 12/13/14 cast.blocks makes 21/22/23/24/25 total k+c on TKI3
- 5/7 plus 18/19/20 cast.blocks makes 23/24/25/26/27 total k+c on TKI4
I'm not talking about using 13deg. block on TKI4, i'm just trying to clarify "19 is new 13" paradigm here:
- Less kickup gives less weight transfer => more responsive, thats good for hi-grip tracks.
- Same amount of overall caster makes car not so twitchy and usable on low-grip/bumpy tracks.
- And new 5x1.5 pistons brings weight transfer back a bit.
There we have:
#803
Wow, tryin'a read through that and keep up with it nearly sent me into an aneurysm. Personally, i highly recommend running stock first and then making changes as needed, not in relation to what the old vs new geometry was
#806
7° Kickup / 19° Knuckle / -1 / 0 / +1 Knuckle insert = 26 / 27 / 28 total caster TKI4
Take out the 11° and put in 7°
Take out the 9° and put in 5°
#808
- 9/11 plus 18/19/20 cast.blocks makes / -1 / 0 / +1 Knuckle insert 30/31/32 total k+c on TKI3 Max I believe this is right
#810
Its not all abaout castor, you need to take the rollenter into the equation too..With the TKI4 front plate you raise the lower hingepin and that gives you less front end grip in theory. So, while you castor decrease and gives you more steering, rasing the hingepin gives you a bit less steering, its a compromise, giving the TKI4 a bit more steering than the TKI3.
