Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#3061
I have measured my rear springs and theyre 85mm. I have (tried to) highlighted the ones i believe i have in purple on the spring sheet (IS106-8514). Am i correct in saying i would want the ones highlighted in green (IFS004-1114)?
#3062
It’s difficult to tell from the photo but if the rear shock body is more than 55mm (standard as pictured) then you need the 95mm springs.
#3063
R/C Tech Elite Member
I didn't consider maybe the springs are wrong since the guy i bought the car from said it had been setup as mike cradock said to (and i know he knows what hes doing).
Either way i need to buy more springs as spares/tuning options.
Just to be clear (sorry I'm still getting my head round this)
I'd take the MC 'said to set-up' with a pinch of salt to be honest, unless he gave you some sort of proof. I know Mike pretty well and he's usually way to busy at a meeting to be running a 2 minute advice clinic...unless this geezer actually knows him and can contact him away from that environment.
#3064
Hello Max Rackstraw,
The Orange Spring that You measured on the picture is indeed IS106-8514, or the one that You highlighted with Purple.
Cheers..
Cheers..
#3065
Mate, you're gonna give yourself a mental hernia...if it's the first MP9 you've had, just put all the shocks back to standard box/kit and start from there. Otherwise you'll never be able to figure out where to tune the suspension from, if you don't know what the car is like to drive at it's very base setting and build your base setting from there.
Honestly thats what i thought i should do, just put it back to stock, like i said i didn't even put these parts on the car so i don't even know what changes it made to handling over stock. Id like to use these option parts but only if set up correctly.
#3066
#3067
Not sure where you're most likely going to be practicing/racing, but if it's at Herts, you seriously won't need to make that many changes to get it to work well around there. The MP9/10 are very well suited to that track.
#3068
100% do this mate and get all the option parts you want, that fit your budget etc. I did exactly the same thing when I bought my first TKI4...built to kit settings first and worked outwards from there. Apart from a maybe a few generic things people do with whatever brand they like, trying to use someone else's set-up is like wearing their trousers...completely pointless, because it won't fit right for you.
I think currently the car has the high mount on the front with big shocks and high on the rear with standard shocks. From what i see online and what you meantioned... I dont need any of that for herts. (To be honest i thought that was the case from the beggining) thanks again!
#3069
Yup sure am going to be racing at Herts, glad to know it doesn't need much tweeking. Im going to get the standard shocks and towers and keep this stuff for spares/tuning options.
#3070
Just rebuilt my center diff, smooth as butter but when I manually turn the drivetrain from the front wheels, it makes a squeeking sound.
This only happens when the drivetrain is turned from the front wheels, turning the rear wheels does not cause it.
I have not run the car under its own power yet. Only just finished the rebuild.
Any ideas what could be causing it?
Or is it just nothing to worry about?
#3071
#3072
#3073
Just posting this up here, as hopefully it'll avoid me having to tell some scamming turd to GFT, with their dumba$$ PM via the WTB section.
Would anyone have a decent chassis (IF473) kicking around, for a sensible price in relation to condition. Not fussed if it's seen some track time, as long as it's not beat to death. Drop me PM with details and decent res photos.
#3074
