Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#2896
Houston, your love of these pistons made me want to try some. I’ve ordered the M2C "Thru" O-Ring Shock Pistons (4) (8x1.3/4x1.3 Hole). Do you run slot up or down? I currently run 500CST F/R 8x1.2 / 8x1.3 I noted you say these piston need a much lighter oil, any suggestions there?
after much playing/testing
i have found .... these to be correct hole sizes
5 hole 1.7mm
6 hole 1.5mm
8 hole 1.4mm
theres no oil blowby around outside of piston because of the oring so all oil is forced to run through holes ...... lighter oil is BAD ...i found correcting hole size to be much better feel
#2898
I need more details on MP10, cannot wait!
#2900
#2901
What are the advantages of changing over to the Evo steering rack on MP9 nitro buggy?
#2903
For $22USD it will give you a hole about 2.6mm more in either direction - front/rear. How that translates to each side is about 0.05mm loss/gain or in the old measure - a bee's willy. For my money I'd go the with ST ball ends ($6) KYOIS053, flip the TKI4 plate to face rear and you have the same setup as the stock MP10.
#2904
broad range of adjustment with if517 plate ..... yes you can flip the mp9 plate 180° of its original intended position and have the same adjustments as if517 "almost" ...lol
as for the offset ball ends from the strr they are now HD - (heavy duty) .... they do not change geometry but do provide clearance for inside lip of rim so it does not hit when at full lock on steering
hope this helps and happy motorin'
#2905
#2906
thanks
in regards to ackerman plate and steering arch these pieces do have some adjustment ........ in regards to bump steer gain/loss that can be adjusted by different washers and spacers ...... another sort of "dark art" in chassis adjustments
#2907
Hey fellas.
In the market for a new starter box. Currently have the hudy box but it’s getting a bit old. I want something that will fit my mp9/10 however I want something that is easyish to push down and start as my partner is usually my pit crew and she is quite small and short so also something light would be nice to (understand I can’t have it all). I was leaning towards the ultimate box but still unsure. Post your boxes if you got em
#2908
Hey fellas.
https://www.amainhobbies.com/kyosho-...kyo36209/p9126
#2909
Just like Morpheus I am new to nitro. I also decided on the the Kyosho 2.0 because of the adjustments and the small size of the starter wheel. Parts for it are easy to get too. So far I like it. I have used the DuraTrax and it was fine but the starter wheel is large and the box wasn't setup perfectly for the Mugen buggy going on it so the wheel would contact the chassis all the time. The Kyosho box starter wheel is so much smaller. The added plus to that is it will have more torque. I also used the ProTek. It works just fine. My only complaint is how ruff it looks after a year of use. The guy that owns it is a clean freak and really cares for his stuff and it looks bad. I think the nitro attacked the paint. I've been told the OFNA is the one to get but I haven't used one. Hope this help you out.
#2910
Hey guys long time no post heh
Will a tki4 chassis be completely plug and play everything bolt on with all tki3 parts? I want to get an aftermarket chassis made for "tki4" but I have a tki3 model. Will all my tki3 parts bolt onto a "tki4" made chassis?
this one:
https://www.ebay.com/itm/7075-T6-Bla...UV5b:rk:7:pf:0
Thanks for any help
this one:
Thanks for any help
