Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#241
Jeromerc what Fusion engine are you running? I just got a 7port ceramic. And was wondering if you ran this in the mp9 or the 5port. I can't find much info on them anywhere. On their website looks like they are outta Australia via Novarossi. He dude claimed to get killer run time with it.
#242
Guys. First time building the k car (tki4) after running mugen for the past 3 years and I'm having issues with the centre diff out drives rubbing/binding against the brake pads. Is this normal - seems to be severely effecting the drive train. Note: I have used the correct out drives.
#244
I got the agama engine mount, could not see paying 50 bucks for a two peice mount from the 777. But I have not seen this or any after market Mont on Tki4
#245
Also where is best place for kyosho parts... Amain site is getting crazy to navigate... Anywhere cheaper? Besides eBay lol
#247
the car does not need any different mounts, the clutchbell thing people talk about is a non-issue, i replace clutch bearings after 4 or 5 races and have not had one fail..
if your constantly lawn darting no need to spend 50 dollars, m2c make a 1mm shim for like 4 dollars or something.. pretty simple
#248
Your brake pad bolts look tight, do the pads "wiggle" at all? Also like previously said, put the top plate on as this makes everything square. The only thing I can gather from the photo is it is not square or your brake pad bolts are too tight the fit on the brake rotor looks good
#249
I know this is a new car, and I have never run a Kyosho....switching from Mugen, but just heard about people drilling the chassis, and using Agama mounts to raise the engine. I saw where Tebo had older 777 mounts that were blue on his car at the DNC....I hope its not an issue on the TKI4....cant wait to run this car : P
#250
Running the taller mount is a good ideal.There's a reason why Tebo runs it. I also do reccomend drilling the hole. Flaming out isn't an issue and that's not why these mods are done. There's a lot of chassis flex on the mp9 cars. The the tki4 is no different. This causes excessive clutch bell contact which is hard on clutch bearings and your engine over all. Some will disagree and that's there perogative. The designer himself drills the hole so that there will tell you something.
#251
#252
Well this being a new car, if YK is drilling a hole in the chassis then when he designed this one should have fixed it or designed it in it... Lol we will see how it goes =)
#254
I use this, no clutch bell issues, and traction is unaffected in my experience
#255
