Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#211
No worries guys
#212
our track is one of the lowest grip tracks in Australia as recently confirmed at our Nationals round 1 where a lot of the interstate drivers were struggling to find traction, so I was a little nervous about switching from Xray to the TKi4 knowing that the updated car was aimed at maybe higher traction tracks. First qualifier, car as per build, 0 changes, yes the rear was loose, was a bit unhappy with it. In hindsight, 50% of this came down to how I was driving it. A local fast guy pointed out to me that i should alter my driving just a bit to accomodate the cars corner speed, use less brakes and let the car drive around the corner. My brother who has been driving the tki3 for a while now helped out with the setup. A total of 3 changes from the book build were done - stand the rear shock up 1 hole on the tower, give it less anti squat( i flipped the rear front pills) and rear camber link all the way down in the tower (length unchanged.) by the 3rd final qualifier it was hooking up as good as anything i have driven on that track. I qualified 1st in the B, left it unchanged for the finals and won quite easily, the car was literally pulling a lead around every corner, on the rest of the field, I have never experienced anything like it. the steering was plenty, yet smooth and never unsettled, and this also helped my consistency.
so in summary, the corner speed has been improved, i would say easily one of the fastest yet easy to drive cars available right now. it was extremely easy to set up for a loose track, minimal changes required from box setup, did i say this thing is fast? I can see why cody king, boots and tebo were running quick at Neo. very impressive buggy. no regrets on switching.
btw the fast guy who helped with the driving tip had a good 10 minute drive, and was extremely impressed, to the point where he said he's going home to order one.
#213
I could be wrong but i kinda feel higher rear link in rear gives me more off power rear traction and lower link seems to give me more on power rear traction, with more initial turn in
#214
tki4 manual, exploded view etc is available on kyosho website
#215
Just out of interest, for the people with a TKi3 how many of you dremel the chassis below the clutch bell?
I noticed Tebo runs the taller blue engine mounts.
I assume you will do the same on your TKi4's?
Ta
Ta
#216
Sure it's the same on tki. But to gain rear traction on my 815 you lower the rear link
#217
What is the part number for these taller blue engine mounts? Are they from the MP7.5, MP777?
#219
usually, going down on the camberlink gives less rear traction. It might be that your car starting to gain traction after some running. I know mine did in the first liter or two. After that it was very consistent.
#220
#221
I took a quick look at the manual but didn't see anything about shock oil viscosity. What's a good starting point for front & rear shocks with the included 5x1.5 pistons?
#222
A lower link is less traction at low speeds/off power, but when you get back on the gas hard, the car kinda straightens out and holds its line. I guess it isn't an all round 'traction' adjustment per se, more that you can get on the gas sooner on a loose track without the car fish tailing, all depending on exactly how hard you hit the gas.
Shock oils I started 37.5 front 32.5 rear Associated oils, seemed to work well
#223
Exactly this.
#224
#225
Took the liberty of going through the exploded views and comparing part numbers to see what changed. The only option part included in this are the 19* front hub carriers, but the 13* are about the same price. The short story is if you're looking to convert a TKI3 to a TKI4, buy a new kit.
Here is what I found:
