Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#196
Can the pins in the dog bone be replaced with the mugen tool or is it next to impossible like the d815...
#198
Is there any advantage to universals compared to the rebuildable CVDS?
I've noticed that some models have switched from CVDs to Unis as they evolved, like mp9 to mp9tki3 & mbx6/7 to mbx7r
#200
Gavel- so u got your D815 converted to universals? If so, any perceptible difference in driving through bumps or how the car corners?
#201
Had my first club meet with the TKi4, car is on point. Had to adjust my driving style from Xray, but that was really the only negative, as far as swapping brands.
Kanai wasn't kidding when he says he improved corner speed, it is just fast, everywhere, period. Very impressive.
#203
Did you have to much steering?
Are you happy you switched to mp9 vs the xray?
#204
UNIs have less resistance, are lower maintenance and more durable all steel construction. Some like the CVD/CVAs because of feel as in more planted/stable. They are very high maintenance with all the pins/cup wear. Since the cups are usually made of aluminium. Then they are very susceptible to binding from dirt mixing with the required grease. Hence the need for boots that always tear. Which also promotes faster wear. Cav is running CVAs on his RC8B3 instead of the UNIs. Tebo's car looked plenty stable and planted to me with the UNIs. To me personally UNIs are the way to go.
#205
I have a couple of 34mm Werks clutches that I love on my Speed. Is there a need to shim the motor up with a 34mm? I was concerned about it bumping the ground on hard landings. Anybody run a 34mm on a mp9 that can relate some experience?
#206
so in summary, the corner speed has been improved, i would say easily one of the fastest yet easy to drive cars available right now. it was extremely easy to set up for a loose track, minimal changes required from box setup, did i say this thing is fast? I can see why cody king, boots and tebo were running quick at Neo. very impressive buggy. no regrets on switching.
btw the fast guy who helped with the driving tip had a good 10 minute drive, and was extremely impressed, to the point where he said he's going home to order one.
#208
I only had the issue once with a 34mm flywheel, it was a small rock sticking up out of the track, once i got a 32mm never had the problem again but there might be that one fluke incident and according to murpheys law it will be when your in front, so if you can get a 32 it isnt going to hurt you
#209
our track is one of the lowest grip tracks in Australia as recently confirmed at our Nationals round 1 where a lot of the interstate drivers were struggling to find traction, so I was a little nervous about switching from Xray to the TKi4 knowing that the updated car was aimed at maybe higher traction tracks. First qualifier, car as per build, 0 changes, yes the rear was loose, was a bit unhappy with it. In hindsight, 50% of this came down to how I was driving it. A local fast guy pointed out to me that i should alter my driving just a bit to accomodate the cars corner speed, use less brakes and let the car drive around the corner. My brother who has been driving the tki3 for a while now helped out with the setup. A total of 3 changes from the book build were done - stand the rear shock up 1 hole on the tower, give it less anti squat( i flipped the rear front pills) and rear camber link all the way down in the tower (length unchanged.) by the 3rd final qualifier it was hooking up as good as anything i have driven on that track. I qualified 1st in the B, left it unchanged for the finals and won quite easily, the car was literally pulling a lead around every corner, on the rest of the field, I have never experienced anything like it. the steering was plenty, yet smooth and never unsettled, and this also helped my consistency.
Wonderful information. Thank you for your time on this.
Waiting on my shell to get. Back.. Then. Im on. The track.
#210
