Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#1862
I have two MP9 issues I'm hoping the community can help with.
Does anyone have the part number for the losi body mount the kids were using? I see two part numbers when I search.
More importantly, what kind of fuel tank are people liking? I installed a brand new Kyosho tank and had nothing but issues Saturday. I am totally open to alternatives. I have heard either turning the factory tank into a clunker style or using the Xray tank.
What is working for you guys??
suggestion ... clean out your hsn by removing needle and blowing fuel through system ... replace needle to factory suggested turns from bottomed .... start over
is it running inconsistent?
and btw .... i have tuned every brand a thousand times over and im not just saying this to say this .... the kyosho fuel system is literally THE most consistent fuel system i have ever tuned
#1863
before hooking up your fuel lines blow fuel through the lines unhooked from the carburetor .... this will clear any debris that can plug your high speed needle
That's the weirdest part of the whole scenario though, it seems to hold tune just fine. If it doesn't flame out on return to neutral (25% chance maybe) it will hold that higher idle and return to lower idle and it is repeatable and changes correctly when you adjust needles.
I hope to find some time in the garage tonight to start troubleshooting. I really do appreciate all the advice from the community and will likely stay with the Kyosho fuel tank as I have the highest respect for Kyosho, particularly with 1/8 nitro stuff. I have been around since the early days and you can't help but notice their domination of the class.
If you were willing to advise me on the mani/pipe you like best for a P5 where top end power is of absolutely no use, need all bottom possible. Running the novarossi 41021 with 2096 right now, has good power, but if I could increase low end power I would, our track is very tight.
Again, thanks to the whole community for assistance
#1866
OK, the story takes a new turn. So due to weather and real life, didn't get to test my angry car. Anyway, so I put the car back on the bench last night to prep for hopefully this weekend. I didn't have much time, but I was about to start pulling fuel lines and blowing into them to double check for any leakage, and I think I located an issue. It seems I have lost my carb retaining screw. I think a well meaning friend may have thought it was the carb stop screw or low side needle or whatever, but I seem to have no carb retaining screw.
Amain doesn't have them in stock, does anyone know what kind of screw I can put in there? Is this something that has happened before and I need to check that screw or did someone likely loosen it on accident?
But I think lack of carb retaining screw might be my weird running issue.
#1868
OK, so because I internet bad and don't have a good place to upload pics and link them like a normal human...
I added pics to the racing stuff album on my profile.
If you look at the pics, I think I'm missing a screw
Is this something that I should have been checking? I thought I was pretty good at looking over the car between runs, I would hope I would have seen that thing backing out, but what the heck then?
#1869
https://novarossidirect-com.3dcartstores.com
#1872
Just a FIY. Novas come with the screw for the carb loose. you must put the carb in the right angle and then tighten the carbretainer.
#1874
Has anyone tried imbue brass pistons on this car yet. Looking for feedback.
