Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#1726
IFW469 Aeration Cap Set. Reduces the bouncy of car when hard landing at big jumps and available flat landings. Also improves the grip by loose surface, bumpy track.
IF410 47 Spur Gear. Made by hard steel, high strength. Improves the acceleration. When using this 47T please be equipped with a shim of 1mm under the center differential gear mount.
Threaded Big Shock Set S & M Includes above mentioned aeration cap parts, new hard coating shock cases, HC diaphragms, shock pistons, shock boots, shock end, shock adjust dial, small washers, nuts, balls and c rings to assemble full shocks. Also you can build the shock by aeration type or diaphragm type.
Shock Case Special Hard Coating S & M New special hard coating shock case allows more smooth movement. Reduces oil fouling and keep oil clean for easy maintenance.
New Brake Pad. New material of brake pad allows stable and consistent braking. The brake pad is surely glued on plate with special construction to ensure holding these.
By Kanai
By Kanai
#1729
Is there someone that have made a setup guide for the mp9 tki 3/4?
If so, can someone point me in the right direction.
#1731
I prefer to steer you into my threads (universal starting setup and tune up spreadsheet) than making a setup guide as I don't have health, will and time to do it. Sorry about that, but do read the threads and if you need more clarification just ask, I'll do my best to help.
#1732
Ready for Saturday's 1st run! Came from HB (since the hara, d812,d815) drove a tki4 a few months back ......n thought it had a ton of potential Hard to describe the difference in feel, but def different than my d815
#1735
Got this pig put halfway back together. Gotta break this motor in yet.
#1739
https://www.youtube.com/watch?v=iwzc...ZPs2iVk6kscEEj
Looks are for supermodels, cars are for function, don't care how stupid it looks, use lots of tubing
