Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#1711
#1713
I have both the .8 and 1mm thick kyosho bodies. I have to cram down the stock air filter to get body on. Is this how they are rolling with this? Or are there any tricks?(besides running different body or air filter ). Seems like Kanai forgot an air filter was going under this body
#1714
Trying to decide which pistons to purchase. Can someone explain the difference between these pistons? Some are black, some have angled holes. Machined vs stamped? They are all 1.3x8 or 1.2x8.
1.2x8 pistons
https://www.amainhobbies.com/kyosho-...405-128/p37352
https://www.amainhobbies.com/kyosho-...347-128/p33545
1.3x8 pistons
https://www.amainhobbies.com/kyosho-...347-138/p22928
https://www.amainhobbies.com/kyosho-...405-138/p37353
1.2x8 pistons
1.3x8 pistons
#1716
Currently run Mugen and have been contemplating on going to Kyosho. Been racing for a year now and have greatly improved, B main and A main at some big events such as PNB and SIC.
Anywho to make the story short, I keep hearing Kyosho is a much easier vehicle to drive. So I've been thinking of getting one. I don't have access to trying one out because no one runs them here.
Thoughts would be appreciated. Thank you.
#1717
I think the best answer is that if you are improving and continue to improve, I would stick with what you have.
Unless you are getting a sponsorship, it sounds like you are already on the right track. I had a Kyosho and just switched to HB racing. Kyosho's drive awesome, but I do think that they are less forgiving when you make mistakes (from a durability stand point). Just my opinion and from someone who has owned just about every brand at some point.
#1719
As for improving, would I not benefit more from a buggy that's easier to drive?
#1720
Thanks for your reply. As far as being sponsored, I don't see a real benefit unless I was starting from scratch, which I'm not. I can sell my vehicles that are still currently new and unran for roughly what it will cost me to get the K cars (lots of option parts installed on the mugens) so only thing I would be losing on is the spare parts I have gathered over the year.
I'm not trying to steer you away from Kyosho because I think it's a great car. It does have more stability than most cars I've driven but it really responds well to setup changes.
#1721
and are you serious about 2 degrees rear toe with HRC pill location? good way to generate zero traction imo.
#1722
when you drive it you will know
#1723
Common complaint with that setup is too much rear traction
-using the hub height high then use the lower row on the hub for the upper arm and using the hub low then use the upper row while keeping hole #8(if not mistaken) on the shock tower.
In hindsight I should have recommended that way from the beginning since I knew that from years ago. Updated and corrected the setup. If there is a lack of rear traction then something is very wrong on my recommended start and further inspection is needed.
#1724
#1725
the tank is designed to be used with the big stock filter and around 20cm of fuel line, are you using these?
