Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#1696
what is the correlation between flywheel diameter and diff spacing?
the stock flywheel is 32mm, if you run a 34mm flywheel it will be 1mm closer to the ground. if the flywheel touches the ground hard enough you will flame. to avoid this you can space the engine/flywheel/clutch up 1mm to compensate, not the centre diff.
https://www.amainhobbies.com/kyosho-...yoif466/p37365
#1697
Just getting into nitro, and 1/8 in general, but I would think if I moved the engine up 1mm I would personally want to move the center (centre) diff up 1mm also. Isn't that the point of this parts tree?
I always shim my center diff housing to the lowest safe height in order to keep the center of gravity as low as possible. This is why Kyosho uses a 32mm flywheel to keep the Center of Gravity low.
#1698
ideally you dont space anything up and keep it all low as possible. the stock 46t spur does not need to be spaced up at all on a new chassis, however if you run on a rocky/gravel track you may choose to.
the only reason you would consider spacing the engine up is if you want to run a 34mm flywheel or to avoid clutch bell strike.
to answer your question directly, if you space the engine up, no you do not need to space the diff up also, you just need to re-set correct mesh.
#1699
as winners circle has correctly point out, those spacers are to compensate for the different spur sizes / track roughness and chassis wear.
#1702
There are different spur gears that you can run in order to get the gear ratio you want for the track you are on. The larger spur gears will hang out of the bottom of the car or nearly hang out. That is the reason you have extra spacers so that you can shim up the center diff housing to keep the spur gear up and out of harms way.
#1703
Anyone looking for a TKI4 brand new built and very nice look me up.
#1704
Anyone know where I can get the 4x8mm flanged engine mount screws for the underside? It appears KYO only offers them with the actual engine plate.
https://www.amainhobbies.com/kyosho-...yoif431/p34706
#1705
#1706
I have both the .8 and 1mm thick kyosho bodies. I have to cram down the stock air filter to get body on. Is this how they are rolling with this? Or are there any tricks?(besides running different body or air filter ). Seems like Kanai forgot an air filter was going under this body
#1707
i put either a layer of shoe goo or aluminium tape on the body at the filter location to protect the paint and have never had a problem.
obviously kanai didn't forget the filter, but he did manage to make one of the lowest profile, sleek and sexy bodies ever for an 8th scale buggy!
#1708
I agree, like the looks of body. Also like stock air filter. But the body will not rest on body posts. It's suspended by air filter. I then press on body and get clips in. Doesn't feel good. Worried about linkage and brakes. It's an OS if that matters
#1709
Its ok, just put any kind of protect tape onto body in that place where filter pushes it.
#1710
Use a Losi air filter set up and your problems are solved. I've had the issue of the air filter hung up on the linkages. Not a fan of using the Losi parts but it makes things easier and trouble free.
