Wheels spinning on idle os 21 engine >
Old 01-28-2016, 06:58 AM
Default Wheels spinning on idle os 21 engine
Iv'e bought a new os 21 engine and then i started to do the 1st tank break in when the engine starts to warm up the wheels starts to spin rather fast to the point i have to stop the engine the idle gap is very small. My thoughts would this be down to the lsn being lean making the wheels spin at idle. Thank you.
hotrob1 is offline
Old 01-28-2016, 07:03 AM
Jerm13's Avatar
Trader Rating: 36 (100%+)
After you reset your needles ( if you need to)....
Stiffen up the clutch springs so they wont make contact with the bell. Your clutch is engaging at too low of an RPM.
Jerm13 is offline
Old 01-28-2016, 07:12 AM
Jaymancd's Avatar
I would say richen the LSN to where it is flush to the housing and then check your clutch. Check the springs the shoes and the bearings. When bearings go bad they will not allow the engine spin without the clutch engaging.
Jaymancd is offline
Old 01-28-2016, 06:18 PM
bypass911's Avatar
Trader Rating: 14 (100%+)
It's also possible your clutch is stuck on the clutch bell, if one of the clutch spring broke or loose.
bypass911 is offline
Old 01-28-2016, 06:32 PM
Frank L's Avatar
Trader Rating: 148 (100%+)
Which OS engine??
Check the clutch...
Frank L is offline
Old 01-29-2016, 12:13 PM
Talon8T's Avatar
Talon8T is offline
Old 01-29-2016, 01:24 PM
Suspended
Trader Rating: 61 (100%+)
I have a feeling the "OS" engine you have isn't the OS engine we think it is:
http://www.rctech.net/forum/nitro-of...l#post14331143
Socket is offline
Old 01-29-2016, 02:07 PM
Suspended
He seems to always have a problem with the wheels spinning..
http://www.rctech.net/forum/nitro-of...-starting.html
http://www.rctech.net/forum/nitro-ro...-spinning.html
Socket is offline
Old 01-29-2016, 04:39 PM
Suspended
Originally Posted by Socket
LOLz, awesome find. This Hotrob1 does not know how to tune, clueless he is.
HR1, there are plenty, and I mean gazillion videos on Youtube. Seems to me you are doing things because other people do them, but you have no idea how each part on nitro engines, clutches work.
crankestein is offline
