Like Tree87Likes
TLR 8ight 4.0
    Hide Wikipost
Old 07-09-2016, 05:15 PM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 8ight 4.0
Last edit by: racer1812
Welcome to the 8ight 4.0 Wiki!
Print Wikipost
Old 02-12-2019, 10:44 PM
  #1471
Trader Rating: 20 (100%+)
Originally Posted by wfo View Post
Most of the expert/pro drivers at my track are using J&T bearings they are really good bearing clutch and car. They have a online store and stock other cool parts.
thatís a really great website man, thank you!! I really like some of the ceramics for 5 bucks! Do you just get the kit bearings? Iím not really into one side being a metal seal but I see the individuals are a buck and they are both rubber! Iím gonna get to finding some more I like, I see they have like thrust bearings in clutch size, thatís the craziest bearing!! Wonder if they r made for clutch bearings lol
Matt Piva is online now
Old 02-13-2019, 04:47 AM
  #1472
maddog9's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Matt Piva View Post
Iím pretty sensitive to my bearings not being cleaned out. A new untouched bearing in my buggy would throw the car outta whack where I could notice it. I run a set of bearings awhile so Iím ready for a step up so they last longer being messed with so much
Must be that hidden speed JQ talks about. I can't tell difference between a 1 dollar or 3 dollar bearing.
So you take a brand new bearing and clean all the grease out that someone specifically designed to have grease or lubricant in their bearings?
I bet if you took a TKO bearing for the clutch and left them the way they are probably last a long time. I know pros like Ryan Lutz swear by the TKO bearings for the clutch bell.
token likes this.
maddog9 is offline
Old 02-13-2019, 10:11 AM
  #1473
lolol ---- I like Avid bearings. Been running them in my cars for years and never had an issue with them. At $1 each. there is no maintenance, toss em and install a fresh one, done.....
maddog9 and TheWorstDriver like this.
token is offline
Old 02-13-2019, 10:34 PM
  #1474
dude donít put me in the same category as jq, you donít know who I am. You didnít even go look at my post after that comment regarding why I said that! donít talk down to people you donít know, you would be surprised who I really am behind this alias. Iíve tested this and the difference for years on this matter. Itís absolutly noticeable to any good driver, sorry your not one of them. If your really that dull to think cleaning out your bearings around an entire car and then throwing one greased bearing in wonít be a noticeable pull in a hub bearing, well then your not very on top of your stuff or donít care. Iím meticulous about my stuff.
Old 02-14-2019, 04:03 AM
  #1475
maddog9's Avatar
Comparing or putting you in the same category as JQ is a compliment. I think JQ is hilarious and makes the hobby enjoyable. I also love all the out of the box testing he does to see what works and what doesn't.
I think a normal 1 dollar bearing such as ones from Avid Rc is perfectly fine. As soon as they get gritty toss it out put another one in. The only place i think bearings matter is in the clutch bell just because of the heat and strain.
So for a clutch bell i would say spend the extra money on something like a TKO bearing or a ceramic bearing.
maddog9 is offline
Old 02-15-2019, 08:53 AM
  #1476
TheWorstDriver's Avatar
Originally Posted by pat dillon View Post
you must be professional driver knowing brand new bearing not perfect. I don’t have time to clean every bearing and oil.
Seriously though...
Car bearings:
Keep in mind the cleaning process of your car. Using things like a WD-40 baths and air compressors will push debris into bearings and shorten the life of the bearing. You don't need to be a pro driver to understand this. I've run Losi, Mugen, Kyosho, Xray, and Avid bearings, I destroyed all of them with WD-40 and an air compressor. Later,.. I learned like everyone else eventually does that's BAD. lol. I use a dry brush for the main dirt, a light spray of simple green & with a rag, and a final touch of SC1 so dirt doesn't stick the next time. I avoid blowing wet cleaners and solvents into the bearings when dirt is present. I mostly ran Avid bearings and keep my stock ones as a backup, or run them only on the practice car. Replace as needed, but replacing in sets does help keep track of bearing life in certain parts of the car. For example: if a left rear wheel bearing is gritty and near failure, change both the left and right in a pair. If you do this you should have equal rotational resistance on both sides of the car if that matters to you. Admittedly, and from experience, most my bearing failures are self inflicted due to to improper cleaning.
Clutch bearings:
I run in multiple sets of bearings in during engine break-in, wipe them off, and set them aside for later use. When idling for break-in the excess grease comes out and leaves only whats needed a thin film. I now use the TKO in the race car, and Avid in the practice car.
If this was a 1/10th scale thread, cleaning your bearings and oiling them often might be the ticket. However this is 1/8th scale baby,.. run'em, hard, and have fun, dont spend your life oiling every bearing. This is only my opinion, but it was formed many years ago.
Cheers!
TheWorstDriver is offline
Old 02-15-2019, 10:18 AM
  #1477
Super Moderator
DRTMI's Avatar
Trader Rating: 27 (100%+)
I would suggest that you boys stop acting like school children and start acting civil towards each other. The other option is vacations from the site,
DRTMI is offline
Old 02-15-2019, 10:20 AM
  #1478
Originally Posted by TheWorstDriver View Post
Seriously though...
Car bearings:
Clutch bearings:
Cheers!
sounds good. I also believe blowing into a bearing isnít a good idea if one or both seals are on. I usually just take the seals off and let them sit in a medicine bottle of wd to dissolve or break down any grime. Then I put them in a clean bottle separate with white lithium, I really knock the bottle around to get anything still in the bearing out and then I clean them of access oil and clean the seals and move to the next one. Iíve been looking hard for a bearing that would be more free under the way I clean my bearings but Iím sure itís not going to be much different. Part of this is just wanting to try something new, to see inside a different bearing thatís not a cheapo bearing and see whatís different. The seals probably make a big difference in prices. The tko bearings (like I said) were very different, more balls and should have been better however they were hard to pop seals off(it was my first time) and I think most got damaged. So unless I wanna just run them without seals I doubt they ever see the track again.
Old 02-15-2019, 12:21 PM
  #1479
My apologize to everyone. Wonít happen again lol we was just playing to hard.
Old 02-15-2019, 01:53 PM
  #1480
But it was fun....
maddog9 likes this.
token is offline
