Like Tree87Likes
TLR 8ight 4.0
    Hide Wikipost
Old 07-09-2016, 05:15 PM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 8ight 4.0
Last edit by: racer1812
Welcome to the 8ight 4.0 Wiki!
Print Wikipost
Old 11-03-2018, 11:19 AM
  #1456
Thanks for the reply guys...
I'll replace the cups and drive pins.
Going thru my 3.0, there are a lot of worn out drive parts. But what I find a little disconcerting, is how the parts are wearing...
For example, the axle drive cups show wear on the shaft that rides INSIDE the hub carriers, as if the cup shaft was spinning inside the inner bearing race. Same goes with the outdrives on the diffs. Same goes with the front A-arm pivot bushings. They've worn out the arms instead of the shaft wearing out the bushing! Thankfully the arms are cheap...
Another good example, which brings me to my next question...the shock caps. They have bushings in them, BUT my cap mounting holes are all elongated from the bushing play. I have to replace the expensive cups instead of the cheap bushings!
So question, I assume it's okay to go with the 4.0 bleeder caps as long as I get the 4.0 bushings as well, seeing as I have to replace the caps anyway...?
As far as rebuilding these worn parts, I'm gonna use tiny amounts of Loctite or maybe a touch of silicone where the bushings mount on the O.D. to ensure the moving parts work as designed.
WuNgUn is offline
Old 11-03-2018, 03:00 PM
  #1457
Sorry...checked the OP and saw that I also need the standoffs....
All good
Rfields likes this.
WuNgUn is offline
Old 11-05-2018, 08:34 AM
  #1458
So cross referencing the parts that I need with the 4.0 parts, I managed to upgrade to the 4.0 front spindles and carriers, rear carriers and CV axles F/R, the bleeder shock caps (and mounting hardware) and of course, drive boots.
It cost me less than $30 more than if I were to stick with the 3.0 parts. Well worth it...
WuNgUn is offline
Old 11-17-2018, 07:12 AM
  #1459
Assembling front knuckle... I think this is how the instructions recommend the spindle height shims?
Is this hiw the team guys are setup?
WuNgUn is offline
Old 11-17-2018, 09:49 AM
  #1460
maddog9's Avatar
Trader Rating: 30 (100%+)
Not a team guy but we always have run them the spindles high or opposite of what you have them. It seems to give more steering in the high position. The high location was very Similar to when we use to run truggy spindle carriers on the 3.0. I believed that's what the 4.0 is based off of just with up or down adjustment.
maddog9 is online now
Old 11-17-2018, 03:53 PM
  #1461
Thanks for the reply... I'll make the change
WuNgUn is offline
Old 11-29-2018, 06:06 PM
  #1462
Just rebuilt the front diff... And I'm wondering why the flange bearings are so sloppy....
It's as if they aren't captured in the diff housing tightly.
If I put them in one of the housing halfs, it looks right, snug.
But when the two halfs are bolted together, the bearing ID isn't being held.
WuNgUn is offline
Old 02-10-2019, 11:40 PM
  #1463
Trader Rating: 20 (100%+)
Hey guy whatís a pretty upper quality of bearings I could get for my 4.0? Iíve tried the standard bearing kit but want to try something new. Iím looking for a mid upper quality to upper quality bearing, not afraid to look at individual bearings and even really high quality bearings for certain areas of the kit. I would really like to have a great set up threw out my buggy!
Matt Piva is offline
Old 02-11-2019, 05:23 AM
  #1464
maddog9's Avatar
We use Avid bearings just regular 1 dollar a piece bearings.
For the clutch use TKO bearings they are about 3-3.20 a piece and well worth it!
Old 02-11-2019, 09:29 AM
  #1465
Ive seen those before, great value for a decent bearing im sure but compared to the standard bearing they are half the price and Iím looking for something that will be better then the stock bearing. I clean and lube my bearings a lot so the seals need to last. I havnt had bad luck with the stock bearings but they donít seem to keep the dirt out that good, awhile ago I tried a set of tko for the entire car and those seemed to be a little worse. Iím just wondering if certain bearings can keep the drivetrain a little bit more free of dirt.
Old 02-11-2019, 01:03 PM
  #1466
maddog9's Avatar
Ya we don't oil any bearings. Once they get gritty we just toss them out. TKO just uses on the clutch bell bearings, i believe it blue seal to blue seal.
Old 02-12-2019, 01:48 AM
  #1467
Iím pretty sensitive to my bearings not being cleaned out. A new untouched bearing in my buggy would throw the car outta whack where I could notice it. I run a set of bearings awhile so Iím ready for a step up so they last longer being messed with so much
Old 02-12-2019, 08:39 PM
  #1468
you must be professional driver knowing brand new bearing not perfect. I donít have time to clean every bearing and oil.
pat dillon is offline
Old 02-12-2019, 09:16 PM
  #1469
wfo
wfo's Avatar
Most of the expert/pro drivers at my track are using J&T bearings they are really good bearing clutch and car. They have a online store and stock other cool parts.
wfo is offline
Old 02-12-2019, 11:24 PM
  #1470
Some call it being on top of your stuff, I call it a crazy obsession. I have 6 years with one of my old 3.0 Buggyís I still love driving, a lot! I decided to really commit to cleaning all bearings out (taking seals off contact brake cleaner rinse) every 1-2 days of driving it in the last year, (insanity I know!!) they have lasted awhile but I run them with just the residue of wd white lithium and really as free as possible, certain bearings Iíve ran without a shield on one side (like in wheel bearings and the pinion lol) because they are not actually keeping dirt out.. . Kinda sketchy if u donít clean them a lot tho! fresh losi bearing takes a minute to break in but not long if all are the same and greased, u wonít notice it.
My 4.0 is all greased up still after like 6 times at the track, I plan on cleaning them all out fully tho, I like the feel. You canít mix greased and ungreased bearing when one fails or needs a change, especially on the wheel bearings!! It just throws it off.
This is why Iím looking to upgrade to some alternative bearing to clean out and test to see how they perform. Im not worried about them failing, I cleaned a stock set a lot in the 3.0 and watched them last a ridiculous amount of time with only a few I needed to change!
I tried this with tko, it was my first set I took apart a long time ago. Didnít work out but I notice they have a lot more balls then stock. Pretty cool the stuff u see in bearings!! Then the seals, makes u wanna go buy the most expensive boca kit they sell for the 8!! But I know thereís probably a cheaper version you can get that doesnít have the big name but maybe still close in performance and quality!
