Like Tree100Likes
TLR 8ight 4.0
    Hide Wikipost
Old 07-09-2016, 05:15 PM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 8ight 4.0
Last edit by: racer1812
Welcome to the 8ight 4.0 Wiki!
Print Wikipost
Old 11-27-2015, 10:08 AM
  #31
Originally Posted by TIX View Post
I had some time this afternoon and thought most of you would appreciate a thread with a fresh start for the new platform
Thank you!! That other thread was brutal!!
rage1945 is offline
Old 11-27-2015, 02:38 PM
  #32
Frank, any chance you can get mayfield to post his winning setup from the U.S. open championship. Thanks
shark2288 is offline
Old 11-27-2015, 09:16 PM
  #33
FallenAllDay's Avatar
Anybody have some build tips yet on the kit!? Havnt build a new rig since the 2.0 so its been a while.
Also could frank or somebody chime in on when they would use emulsion shocks versus the bladder set up for specific track purposes!? Loving the build so far, liking all the extra up grades included in the kit, cant wait to drive this thing!!
FallenAllDay is offline
Old 11-27-2015, 10:00 PM
  #34
fizzy's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Socket View Post
The kit for $279 and then buying the parts MIGHT BE a much better deal than buying new.
Where can you pick up the 3.0 for $279
fizzy is offline
Old 11-28-2015, 07:45 AM
  #35
Jerm13's Avatar
Trader Rating: 36 (100%+)
Amain has them for $300 plus $25 off coupon right now...so $275 plus shipping ( if you don't get it for free)
Jerm13 is offline
Old 11-28-2015, 09:19 AM
  #36
RCSureStart's Avatar
Getting back on subject... We've found since building the new 4.0, is that the king pin is incredibly tight going through the front hubs, spindles and caster restricting the steering movement. To get round this we used 4mm drill piece to enlarge the hole and have found this helps free the steering up massively. Would certainly recommend this.
RCSureStart is offline
Old 11-28-2015, 09:20 AM
  #37
AllyITA's Avatar
finished the build and painted the body (proline phantom)
AllyITA is offline
Old 11-28-2015, 09:23 AM
  #38
AllyITA's Avatar
yes i did the samewith a 4.2 drillbit (the same i use to ream the arms)
the problem with the spindle isn't that the holes are too tight, it is that the holes are not alligned properly
AllyITA is offline
Old 11-28-2015, 10:58 AM
  #39
Looks very nice!! Great job... now the only problem is its time to get it dirty! !! Lol
flap jack is offline
Old 11-29-2015, 12:58 AM
  #40
+3 they are super tight after i installed mine as well, also the spindles are set in the low position correct?? Im sure there right but i wanted to confirm with you guys.
On another note did any of you guys notice the cv outdrive holes are very close to the outer bearing and just barely lined up with the hex hole!? Mine seems slightly tight in my opinion but i dunno if its because of the rubber boots now on the bones either causing some slight extra friction. Thoughts??
Old 11-29-2015, 07:53 AM
  #41
mv91pony's Avatar
I had the same issue. Took a hobbyknife to the edge of the axle and prob solved. Drivine does have a bit of drag on it. But it is new and i remember that tlr s are bit tight when new. I did notice that theres no need to do anything with the turnbuckles. Popped in and were perfect. I also think that the driveline drag is due to the boots. Sure it will free up. In a few hotlaps.
mv91pony is offline
Old 11-30-2015, 07:04 AM
  #42
976
When is the E buggy available
976 is offline
Old 11-30-2015, 08:39 AM
  #43
Jerm13's Avatar
When they decide to make it...
Jerm13 is offline
Old 11-30-2015, 02:56 PM
  #44
Officespace's Avatar
Does anyone know if the 4.0 shock cap bushings will fit on the Lunsford titanium shock stand-offs that I have on all my 3.0's or do I need the new 4.0 stand-offs? Thanks
Officespace is offline
Old 11-30-2015, 05:14 PM
  #45
mv91pony's Avatar
Having both cars in front of me the 4.0 standoff has an hourglass shape to instead of the strait shaft of the 3.0. Also the caps have snap in bushings instead of slid on bushings. Hope that helps.
mv91pony is offline
