Like Tree100Likes
TLR 8ight 4.0
    Hide Wikipost
Old 07-09-2016, 05:15 PM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 8ight 4.0
Last edit by: racer1812
Welcome to the 8ight 4.0 Wiki!
Print Wikipost
Old 11-26-2015, 09:08 AM
  #16
Suspended
Trader Rating: 61 (100%+)
Originally Posted by Frank Root View Post
The biggest change, is the motor/driveline moving. This changes the handling on the car by a HUGE amount. It really drives a LOT different, and a lot BETTER.
Happy turkey day Frank...
Can you explain emulsion vs bladder for me?
Socket is offline
Old 11-26-2015, 09:25 AM
  #17
Originally Posted by Austin's dad View Post
What oil are you running in your shocks?
40 in the front and 32 1/2 in the back. Stock e 3.0 springs and Pistons
87MagnumII is offline
Old 11-26-2015, 09:29 AM
  #18
mv91pony's Avatar
Do current losi chassis weights fit on the 4.0 chassis? Also will it give the same planted feel that it did for the 3.0?
mv91pony is offline
Old 11-26-2015, 10:39 AM
  #19
cornerspeed's Avatar
This is my opinion on emulsion vs. bladder.
Emulsion shocks allow instant shock action. What I mean by is, the piston will start passing oil thru the hole at the start of its travel. So more responsive.
Bladder shocks travel oil thru the piston after the bladder travels, so essentially the car loses travel a mm or 2 before the pistion/oil works. So less responsive.
I have been running emulsion exclusively for well over a year. It lands better, by recovering the landing quicker. Less bottoming out. Plus if there are any higher speed, abrupt jump faces, the car will not bottom out on face of jumps so hard and stay in line without getting car upset.
cornerspeed is offline
Old 11-26-2015, 03:50 PM
  #20
emulsion is very popular with 1/10 scale. I've never seen any pro setups with any of the cars use emulsion in 1/8 scale.
shark2288 is offline
Old 11-26-2015, 04:12 PM
  #21
I bet you start seeing some now. They wouldn't have given us the option without good reason
Old 11-26-2015, 05:07 PM
  #22
ScrewLoose's Avatar
Wondering how difficult it'll be to convert a 3.0 to a 4.0, and if it'll actually be cheaper to do so. I'd be willing to try the new changes than selling the 8ight and going to HB.
ScrewLoose is offline
Old 11-26-2015, 06:25 PM
  #23
spookie's Avatar
Trader Rating: 25 (100%+)
I'm shocked. 4.0 parts are already hitting Ebay.
http://www.ebay.com/sch/i.html?_from...8+4.0&_sacat=0
spookie is offline
Old 11-26-2015, 06:34 PM
  #24
ScrewLoose's Avatar
Based on the prices, looks like it's going to be way cheaper to convert than to buy the kit.
Old 11-26-2015, 06:44 PM
  #25
Suspended
The kit for $279 and then buying the parts MIGHT BE a much better deal than buying new.
Socket is offline
Old 11-26-2015, 08:07 PM
  #26
ScrewLoose's Avatar
The kit for $279 and then buying the parts is a much better deal than buying new.
I started adding up the parts and prices. Total so far is $339.93. Not done yet either
Edit:
Found something odd. The Front Chassic Brace for the 4.0 is TLR241015, but the front top plate is LOSA4413 which is the front chassis brace SET for the 3.0. Not sure if this is intentional, or an accidental oversight, but it seems odd that if you break the top plate on the 4.0, you'll be getting the chassis brace as well, unless the 3.0 chassis brace works on the 4.0.
Old 11-26-2015, 09:03 PM
  #27
just because the front chassis brace is different, doesn't mean the top hole is not in the same location...as it does use the same servo saver and top plate as other versions....the front chassis brace was modified for the different cv angle up front...but the top hole location is obviously the same still
Next-Level-Inc is offline
Old 11-26-2015, 09:06 PM
  #28
pballer2777's Avatar
Trader Rating: 28 (100%+)
Edit:
i just ordered a kit from horizon with their 15%coupon ans it cam to $527
pballer2777 is offline
Old 11-27-2015, 12:18 AM
  #29
AllyITA's Avatar
just a question from a noob of standard screws:
what size nut driver do i need for the shock standoff nuts?
1/4 for the small one (right?)
11/32 or 3/8 for the bigger nut?
thanks
finishing tonight my 4.0 build
AllyITA is offline
Old 11-27-2015, 12:40 AM
  #30
here in Australia the 4.0 landed is close to KY prices.. 799 although it inc. P&H .. its eeh .. but hey if $$$ is willing and on the ready.. looks the goods.. have always had TLR in the back of my mind.. since i sold my TLR XXTCR Truck back in the day.. mmm , as with many.. if you have the option you ll go for something just as good for tad less.. other wise a great looking Buggy! and shouldnt need any option parts.. which is a bit overkill for the price tag.
DaRaceMasta is offline
