TLR 8ight 4.0
#1516
The X shocks are compatible, and the 4mm shafts will work on previous models. Either remove the material that secures the cups or use the tapered cups. If evo setup use the 15mm cups and previous Shaft ends.
X inner hinge pins are 66mm and are compatible not sure about the rear outer pins. Wheel hexes and pins including the XT are the same. The XT uses +4 rear hexes and +2 front hexes.
Rear wings but not the mount
X shock standoffs are basically the same as a 8ight 2.0, Use X bushings thou.
Turnbuckles, rod ends, and ball links will work as a whole set thou the links are the same.
#1517
I have two other unknown part # bones that simply are to long.
This bone also came stock in the box with my 8ight e 4.0 for rear.
#1519
Just got a 8ight-t rtr been bashing around since I cannot get enough traction to try a track without bottoming or spinning out and flipping.
First week curb stomped the servo to death.
Second week a sub zero tree snapped the front center dogbone.
Between breakdowns noticed I needed a little more tuneability to keep the traction so I have 3.0 shocks, adjustable hinge pins, turn knuckles on the way.
Should I upgrade the chassis and/or shock towers? If I did would I be able to get these parts from the 4.0 or would I need additional parts?
#1520
what are your differentials at for oil weight or cst??
I guess is the truck pushing through the turns??
#1521
Both my 8ight 4.0 and E4.0 have changed over the down time.
I had more of a difficult time getting mine to stay flattened out.. would like to flip entering turns or attempting to turn on brambles. I could not do a donut, it would self terminate in about 240 degrees.
A list of things have changed on both from roll center, rear offset braces allowed reduction of overall rear toe in as it will be more with offsets, low profile aluminum rear hubs, longer rear shock tower, x-shocks.. and various bushing mods..
#1523
#1525
