Associated RC8T3 >
Associated RC8T3
Like Tree49Likes
Associated RC8T3
    Hide Wikipost
Old 09-19-2016, 08:08 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Associated RC8T3
Last edit by: sbrewer
Since I don't have one of these yet, Here is the wikipost for those in the know to post all the important info on the truggy!!http://https://www.teamassociated.com/pdf/cars_and_trucks/RC8T3/setup_sheets/RC8T3_2016_Rivkin_DNC.pdf
Print Wikipost
Old 08-12-2019, 03:36 PM
  #781
petersen114's Avatar
Tried this on the B3 Facebook page with very little answers. I have a T3 & a B3 that no matter what I do I can’t prevent air from being sucked into the shock bodies. This happens even with the cap off. New o rings (factory and aftermarket) new bushings machined and the black ones that come with the kit. Several sets of each over the last couple of months. Going broke on shock rebuild kits and bushings. Ready to just give up on the whole deal. Been trying to get ahold of associated for a week now with null responses.
petersen114 is offline
Old 08-13-2019, 07:57 AM
  #782
Trader Rating: 20 (100%+)
Originally Posted by petersen114 View Post
Tried this on the B3 Facebook page with very little answers. I have a T3 & a B3 that no matter what I do I canít prevent air from being sucked into the shock bodies. This happens even with the cap off. New o rings (factory and aftermarket) new bushings machined and the black ones that come with the kit. Several sets of each over the last couple of months. Going broke on shock rebuild kits and bushings. Ready to just give up on the whole deal. Been trying to get ahold of associated for a week now with null responses.
AE is moving to a new location. That's why you haven't been able to contact them. They should be back to normal soon.
MX304 is offline
Old 08-13-2019, 09:37 AM
  #783
MaricopaAgent's Avatar
Trader Rating: 28 (100%+)
If you can find a super thin washer to fit the bottom of the shock bodies, it will help compress the o rings tighter.
Build them with green slime also. I let the o rings sit in a bag with slime till I am ready to use them.
I'm not on the B3 FB pages, all the good questions or even known issues get no response. But when the user screws up, you'll see 25 comments..
petersen114 likes this.
MaricopaAgent is offline
Old 08-16-2019, 03:32 PM
  #784
Has anyone tried the imbue x rings? Looking for feedback on them.
Old 08-23-2019, 11:49 PM
  #785
xfbaap's Avatar
Originally Posted by Torian4000 View Post
I had my first race with the truck this past weekend. I did all the DNC mods and put Cavs Silverstate setup on it with a few changes. Only issue I had was the rear camber link pulled out and stripped the plastic. I grabbed some Mugen MBX7TR links and ends, put them on and solved that problem. Overall I was very impressed with the truck. Here's a short vid of me drving it. (Green with Yellow Wheels)
https://youtu.be/UDdiSNA9XOw
That track is awesome!!
xfbaap is offline
Old 09-14-2019, 11:24 AM
  #786
Anyone know if there is still an e conversion kit for the 3.1t?
JerseyGTS is offline
Old 09-14-2019, 01:58 PM
  #787
track looked hooked. Great driving!!
xfbaap likes this.
Old 09-14-2019, 09:31 PM
  #788
xfbaap's Avatar
x2
xfbaap is offline
Old 09-24-2019, 12:41 PM
  #789
Tech Legend
Cain's Avatar
Trader Rating: 268 (100%+)
looking at some truggy options, based on the new price is there something on the way like a new version possibly early next year?
Cain is offline
Old 09-24-2019, 06:11 PM
  #790
I would assume a buggy would be in the works first. Truggy is like a red headed step child for R&D, and the T3.1 is one of the best.
Shim the diffs correctly, pull lots of trigger.
Old 09-24-2019, 07:04 PM
  #791
x2
You just buy the parts separate, just ordered them by part number from the manual when the electric/nitro build instructions split. About $185 if you ate buying everything new (motor/esc separate of course)
xfbaap likes this.
Old 12-01-2019, 09:31 PM
  #792
artis1's Avatar
Default Flywheel clearance on rc8T3.1
I have a newly built T3.1 and my flywheel is not going far enough down into the chassis hole. Iím not sure if theres a Truggy flywheel or if I need lower engine mounts. I am using all factory parts. Please help.
artis1 is offline
Old 12-04-2019, 11:43 AM
  #793
Buggy and truggy run the same motor mounts and flywheel. Check your starter box for alignment and worn wheel.
Old 12-04-2019, 12:48 PM
  #794
rc pete's Avatar
Some starter boxes don't have the flywheel reach up very high into the chassis slot, so be sure to check that. For example, the Protek one requires that the starter box assembly is shimmed up by 2mm.
rc pete is offline
Old 06-11-2020, 04:35 AM
  #795
So what is the verdict on this truggy? I still have my old CE version of the old truggy. I seem to recall that this new version had some durability issues? Is that the case? Also, is there anything at all which will cross over from the older to the current version? Diffs, pinions, anything? Thanks..
Herrsavage is offline
