Lunsford hinge pins and kingpins for 2.0 used on 3.0 T???
I found a pretty good deal on a set of Lunsford hinge pins and spindle king pins for the 8ight T 2.0. I have checked the sizes, and the kingpins seem to be the same size, just a different coating between the 2.0 and 3.0, which would not matter with titanium. Will these work on my 3.0?
Also, in the Lunsford hinge pin kit, the outer rear hinge pins seem to be only threaded on 1 side ,and has a small stud on the other side, instead of threaded on both sides, and not sure if that will work? Has anyone used the Lunsford 2.0 hinge pin kit on their 3.0, and do the outer rear hinge pins work properly?
thanks Joe Pit, I will grab them up ASAP then. I appreciate the help.
I use the RB one R hinge pins. They are the same size and much stronger then anuthing else I've tried.
