vision racing shock pistons? >
Like Tree23Likes
Old 09-11-2018, 10:41 AM
  #451
Need recommendation for Tekno NT48.3. Medium grip track. Not too rough with some big jumps. From what I have read it seems LP versions are recommended. Was researching and was going to order 8 hole 1.3 LP. However discovered it says on the site to use HB D815 Bellow Baldders? Are the stock Tekno shock bladders not good with these pistons?
OCDMods is offline
Old 10-01-2018, 09:11 AM
  #452
Trader Rating: 56 (100%+)
Which Game Changers fit the Serpent SRX8e ?
Yodah is offline
Old 10-01-2018, 03:26 PM
  #453
adrictan's Avatar
Could you measure the stock piston's diameter and center hole diameter?qqq
adrictan is offline
Old 10-31-2018, 10:08 AM
  #454
wfo
wfo's Avatar
I ran the v3 pistons last weekend at Thunder Alley in So. Cal. and they were really good! HB v2 front - 5hole 1.5 (37.5w) Rear- 5hole 1.6 (30w) My car handled good, as the track was a new layout and pretty smooth. As the day wore on, it got rutted but the car stayed consistent through out the day.
wfo is offline
Old 11-12-2018, 09:06 PM
  #455
banana rt's Avatar
need suggestion here guys,
Inferno TKI3/4
My local track were low traction and bumpy surfaces, with high jumping ramp
which pistons works best suit on that track.
any advice will apprectiate
thx
banana rt is offline
Old 11-17-2018, 05:53 AM
  #456
adrictan's Avatar
The Mugen or Kyosho ones should work
adrictan is offline
Old 11-17-2018, 05:55 AM
  #457
adrictan's Avatar
Inferno TKI3/4
thx
I usually go bigger holes on low traction and if in doubt, always use the stock piston sizes for reference and start fm there.
adrictan is offline
Old 01-13-2019, 12:45 AM
  #458
Default Tekno e-buggy pistons
What is the recommendation for Tekno E-Buggy for an all around solid choice? Which gamechanger piston and which xv3?
codysb05 is offline
Old 01-13-2019, 02:07 PM
  #459
adrictan's Avatar
Hi, the best start off point would be to try the piston size of yr stock pistons and go from there.
Variables like track conditions, types of track, buggy weight etc play a part as well. So there's no thing like a all-round.
Thanks.
adrictan is offline
Old 06-02-2019, 01:00 AM
  #460
Default 6 hole
Hi guys, I bought these pistons for my mugen mbx8
VRP6H1.35/1.45V3MG | VRP Pistons XV3 6 Hole 1.35/1.45mm Splits
VRP6H1.35/1.50V3MG | VRP Pistons XV3 6 Hole 1.35/1.50mm
I would like to know what silicone they recommend for these pistons. in our circuit appears the blue grove and has areas of high traction and low traction. Thanks.
manuelvigo is offline
Old 06-02-2019, 01:42 AM
  #461
adrictan's Avatar
What wt oils were you using on yr stock pistons? If yr stock ones were of similar hole sizes then start by using the oils u used previously. Regions fm 33.5-40wt or 400-500cst is what I go with as a start
adrictan is offline
Old 06-02-2019, 01:49 AM
  #462
thanks for answering.
