Revo 3.3 big block conversion
I'm thinking about doing the same thing. I've read the losi 454 is just an lrp .28 and is an excellent motor for the price.
the revo doesn't hold up too well to a true bigblock..... the chassis is quite weak and easily bends and the drive gears are extremely fragile and very prone to failure.... If all your doing is running around on flat ground you should be OK< but if you plan any real offroading or jumping I wouldn't do a bigblock kit....IMO the Revo just isn't built study enough to handle any sort of big power without turning into a endless money pit that is constantly breaking.....
I replaced my revo engine with the 21tm, better engine than the 3.3 but still not that powerful compared to a true big block .21.
+1, to make a revo last you need to replace nearly everything, including gearing in the centre diff, (you then loose reverse), need to replace them with steel gears, can't remember the name of the company that makes them, you will most likely need a new better quality slipper clutch as well & will need to upgrade driveshafts etc because they wear even with the crappy 3.3 engine.
I'm new to the forum..I would appreciate it if you can tell me if you've had a problem with the gears engaging in your revo....if so what causes this and how can I fix it?? If you know some1 in the forum that can help me with this I'd appreciate that as well if your not able to....thanks
