James Racing Tires >
James Racing Tires
Like Tree63Likes
James Racing Tires
    Hide Wikipost
Old 04-22-2019, 12:23 PM   -   Wikipost
R/C Tech ForumsThread Wiki: James Racing Tires
Last edit by: Evoking1230
James Racing Tire Prep/Gluing Tips
1. Use non-chlorinated brake cleaner or Alcohol to clean bead of tire.
2. Dremel wheel bead. This gives it a good bonding surface. Clean after dremel with above cleaners mentioned above.
3. Use loctite professional glue.
4. Enjoy!
What James Racing Tires are compared to in other brands:
PL suppressor - Y-Zip
PL lockdown - Revenger
PL fugetive - Defenders
PL blockade - Y-Zip or Revenger
PL switchblade - Wasper
Dot Evo works on wet or dusty tracks and every track condition.
Wasper is like a Hole Shot/Buck Shot.
I-Blocks are amazing on dusty blue grooves.
X-Cross is like a Bow Tie.
The rubber wears like iron and the SS compound is close to a M3 PL and if sauced with PB Blaster, feels like a M4. The 5 rib inserts are like Dirt Techs so they don't break down fast like PL foams do.
"Compound Chart"
Originally Posted by Evoking1230
So is there a chart for which compound to go with in what weather/conditions?
I live in Texas and currently in the 70ís-80ís. Lately, occasional 50ís-60ís. And of course the 90ís in the summer and then some.
Thanks.
/Quote
There is no chart, but traction level is more important than temps. Use SS for low grip, Soft for high grip, and Medium for extreme/abrasive grip levels.
Print Wikipost
Old 05-24-2015, 10:38 AM
  #61
Intech BR-6's Avatar
Not that I know of.
Intech BR-6 is offline
Old 12-29-2015, 11:25 AM
  #62
Trader Rating: 134 (100%+)
I am going to go to the dirt nitro challenge this year, what would be a good stable of tires to bring for buggy. I have never ran there.
Breeze is offline
Old 12-29-2015, 11:34 AM
  #63
I've never been to that track but if you tell me what other tires work there, I can suggestion a James comparable.
Old 12-29-2015, 04:01 PM
  #64
I was told holeshots and lockdown M3
Breeze is offline
Old 12-29-2015, 04:18 PM
  #65
Then I would try Soft Wasper and Y-Zip.
Attached Thumbnails James Racing Tires-wasper-j08b06.jpg   James Racing Tires-y-zip-j08b01.jpg
Old 12-29-2015, 07:26 PM
  #66
Where does the dot evo fit in?
Breeze is offline
Old 12-30-2015, 02:39 AM
  #67
The Dot Evo is in between those 2. It is my goto tire because it works on every track condition - dusty, wet,grooved, and slick.
Old 12-31-2015, 03:53 PM
  #68
mv91pony's Avatar
dot evo has worked consistantly at almost every track i. every condition we threw at it. super soft comp. cant wait for dialed to get us the tires new to 2016. try um . you wont regret um. they rip
mv91pony is offline
Old 01-01-2016, 01:40 PM
  #69
Trader Rating: 24 (100%+)
I'm thinking about trying some of these tires at the HobbyPlex in Omaha on my ebuggy in the coming weeks. Any suggestions on what I should use? Since it's ebuggy the longer mains aren't as much of a concern. I was thinking about ordering a set of Dot Evos in SS in place of Typos and something comparable to Gridiron II's I think. (Wasper or Yzip?) Open to all suggestions!
Here is what the AKA track selector has to offer: (all rec's are SS compound for hard packed clay)
Summer time when track starts to blue groove, low dust - Wishbones
Winter time when track has moisture - Typo
Any time when track is dry but not grooved up - Gridiron II
Longer mains when track has grooved up and wear is higher. Temps below 70*F - Catapult
fenton06 is offline
Old 01-04-2016, 09:23 AM
  #70
James does not make any 1/8 indoor tires yet, But the Wasper should be the best.
Fortis/Baster/arrow for 1/10th scale.
Old 01-04-2016, 11:12 AM
  #71
Trader Rating: 30 (100%+)
Ss Waspers work well at hobbyplex
gofast072 is offline
Old 01-04-2016, 07:27 PM
  #72
Thanks!
fenton06 is offline
Old 01-07-2016, 05:40 PM
  #73
Talon8T's Avatar
Originally Posted by Intech BR-6 View Post
James Racing is looking for 1 Pro Factory Driver as good as Jerome Sartel in the USA. If you know anyone looking to make a switch, please have them contact James Racing USA.
Looking for any racers in region 2?? I would love the opportunity to rep these tires!!
Talon8T is offline
Old 01-10-2016, 01:30 PM
  #74
Race-Wright's Avatar
I have been using the Wasper in SS @ JCP Raceway in Indianapolis IN. The track is indoor hard pack clay, most guys use a Electron, Dirt Web, Panther Switch 2.0 or similar tire.
I found the Wasper in SS is just as competitive and lasts longer than the other brands. One set of tires lasted me 3 qualifiers and still had plenty of tread for the mains. As the tire wore the better they got.
Race-Wright is offline
Old 01-11-2016, 06:51 AM
  #75
New James Racing X-Cross 1/8 Buggy Tire.
New James Racing Pentangle 1/8 Truggy Tire.
