James Racing Tires >
James Racing Tires
Like Tree63Likes
James Racing Tires
    Hide Wikipost
Old 04-22-2019, 12:23 PM   -   Wikipost
R/C Tech ForumsThread Wiki: James Racing Tires
Last edit by: Evoking1230
James Racing Tire Prep/Gluing Tips
1. Use non-chlorinated brake cleaner or Alcohol to clean bead of tire.
2. Dremel wheel bead. This gives it a good bonding surface. Clean after dremel with above cleaners mentioned above.
3. Use loctite professional glue.
4. Enjoy!
What James Racing Tires are compared to in other brands:
PL suppressor - Y-Zip
PL lockdown - Revenger
PL fugetive - Defenders
PL blockade - Y-Zip or Revenger
PL switchblade - Wasper
Dot Evo works on wet or dusty tracks and every track condition.
Wasper is like a Hole Shot/Buck Shot.
I-Blocks are amazing on dusty blue grooves.
X-Cross is like a Bow Tie.
The rubber wears like iron and the SS compound is close to a M3 PL and if sauced with PB Blaster, feels like a M4. The 5 rib inserts are like Dirt Techs so they don't break down fast like PL foams do.
"Compound Chart"
Originally Posted by Evoking1230
So is there a chart for which compound to go with in what weather/conditions?
I live in Texas and currently in the 70ís-80ís. Lately, occasional 50ís-60ís. And of course the 90ís in the summer and then some.
Thanks.
/Quote
There is no chart, but traction level is more important than temps. Use SS for low grip, Soft for high grip, and Medium for extreme/abrasive grip levels.
Print Wikipost
Old 12-19-2014, 09:35 AM
  #31
Intech BR-6's Avatar
+ YouTube Video
Super Soft Dot Evo's.
Intech BR-6 is offline
Old 12-20-2014, 07:48 AM
  #32
Trader Rating: 27 (100%+)
where i can order 1/8 tires from? does they will make a truggy tires ?
which 1/8 tires good loamy loose track outdoor ?
thanks
taztal3 is offline
Old 12-21-2014, 07:47 AM
  #33
thanks
You can order from Dialed-RC Hobbies. There are no truggy tires yet.
Dot Evo and Flash should be the best on loamy tracks.
Old 12-21-2014, 08:29 AM
  #34
Are the Dot Evos best for hard packed, super dusty tracks? When are you getting a shipment with the rest of your compounds?
Nino_GPR is offline
Old 12-21-2014, 10:01 AM
  #35
Hopefully the first week of January.
The dot Evo works great on wet loamy and dry dusty tracks.
Old 01-12-2015, 05:59 AM
  #36
Now in stock at Dialed-RC Hobbies - New James T-Shirts and all James Tires.
Old 01-28-2015, 07:07 AM
  #37
Vinny Cancilla's Avatar
For the tracks I race on, most of us run blockades/impacts or gridirons/holeshots, which james tires would match up best with these.
Vinny Cancilla is offline
Old 01-28-2015, 07:42 AM
  #38
The closest is:
Flash - Impact
Wasper - Holeshot
If you want something that lasts even longer for more budget minded consumers, the Super Cross, I-Block, and Y-Zip also work good with larger pins then the Flash/blockade/impact. For super dusty or loose tracks, the Dot Evo has way more traction then Wasper/Holeshots/Gridirons.
Old 01-28-2015, 07:51 AM
  #39
~KANE~'s Avatar
The closest is:
Flash - Impact
Wasper - Holeshot
Where does the square cracker fall on this list?
~KANE~ is offline
Old 01-28-2015, 08:10 AM
  #40
It is in between the Wasper and Flash like a Sniper.
Old 01-28-2015, 04:12 PM
  #41
It looks like a gridiron 2 to me.
Old 01-28-2015, 07:45 PM
  #42
jkas10's Avatar
Trader Rating: 123 (100%+)
I was just on Dialedhobbies and almost every tire is in Stock!
http://www.dialedhobbies.com/search/0/?keyword=james&limitstart=0&option=com_virtuemart& view=category
jkas10 is offline
Old 01-31-2015, 06:12 PM
  #43
mv91pony's Avatar
We had nothing but great performance out of all the tires from dialed hobbies. Cant wait to try the james line of tires as well. Ordering dot evos and the supercross buggy tires as well as some more vp pro striker 2.0s. (great tire) for motorama this month.
mv91pony is offline
Old 02-04-2015, 08:45 AM
  #44
Is it pronounced James or HAHM-ess?
Eastside777 is offline
Old 02-08-2015, 06:08 PM
  #45
triggerman101's Avatar
Trader Rating: 102 (100%+)
I can say that the James tires I have tried to balance really didnt need it. Very surprised about that. As for wear, ive only used them indoors so far but there isnt anything to speek of for wear.
triggerman101 is offline
